will a pickup rear axle fit a 1997 Tacoma
Discussion in 'Technical Chat' started by rab89, Mar 11, 2013.
  1. Mar 11, 2013 at 7:22 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    Anyone know if I can directly swap a rear axle from a toyota pickup, and put it into a 1997 Tacoma?
  2. Mar 11, 2013 at 7:35 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Depends on the year. I have a 94 Toyota truck axle on my 95.5 Tacoma. I would assume it would work as long as it's not from the smaller Toyota trucks from the 80's.
    I can tell you the Pre-Taco's didn't have a BPV, so you'll have to modify it with brackets for it, and likely brackets for parking brake lines, too.
  3. Mar 11, 2013 at 7:54 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Will it bolt in? Yes.
    Will it be too narrow with a different pinion flange pattern, most likely different gear ratio, and not have a the proper brackets for brake lines and parking brake lines.. Yes. All of the above.
  4. Mar 11, 2013 at 10:06 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hmm, too much work!
