Will a Softtoper from an 09 Taco fit my 17?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ReformedFordOwner, May 23, 2017.
  1. May 23, 2017 at 1:39 PM
    ReformedFordOwner
    ReformedFordOwner [OP] Active Member
    2017 Toyota Tacoma TRD Sport 4X4
    Stock
    I have a line on a nice, used, Softopper I am interested in buying but will it fit? He had it on his 09 Taco.
  2. May 23, 2017 at 1:42 PM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    Im.no expert but the rear end is different so im leaning towards no
  3. May 23, 2017 at 1:48 PM
    aleriance
    aleriance Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    I have heard that as long as you're going from long bed to long bed, or short bed to short bed, you should be fine.
    ReformedFordOwner[OP] likes this.
  4. May 23, 2017 at 2:00 PM
    ReformedFordOwner
    Stock
    It doesn't have to be perfect. I just need it to move.
  5. May 23, 2017 at 2:18 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Are these easy to remove? I'd like one for camping maybe, but I wouldn't necessarily want it on all the time.
  6. May 23, 2017 at 2:31 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    It'll fit but will sit higher than the cab line and I believe the tailgate flap (for lack of better words) is shaped differently. It'll work but it won't be perfect.
    If you leave the rails on, removal takes about 2 to 5 minutes.
    OA
    Thunder Fist[QUOTED] likes this.
  7. May 23, 2017 at 2:32 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    Awesome. That's good to know. I've only seen videos of them being folded down, not removed.
  8. May 23, 2017 at 2:36 PM
    Omar RVA
    Omar
    OR
    Essentially all that's left after folding is removing two ring locks that keep the topper frame locked onto the pins on the rail (think like the rings on a key chain).
    Here's a pic from the install instructions:
    https://www.softopper.com/media/wysiwyg/OldBedrailInstallInstructions.pdf
    OA
  9. May 23, 2017 at 2:42 PM
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    I have had both a 2nd & 3rd gen and the only thing I notice is the height of the mounting tracks are lower in the third gen.. and of course no mounting tracks in the front bed of 3rd.
