= => Will A "SPINDLE" Lift Help my Rubbing? 285/70/17 w/4.5 BS @ 2.5 Lift <= =
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RAD, Oct 19, 2009.
  1. Oct 19, 2009 at 10:40 PM
    RAD
    RAD [OP] Well-Known Member Vendor
    Rad
    LAX & LOGAN
    So I've got some minor rubbing here and there. Like some other threads, some people ended up cutting the cab and I don't want to do that at all. I've consider cutting it & welded back by Demello.
    However I'd rather avoid that if I can just do the Spindle Lift. I've been told by a few other Taco owners I can run a 3.5 Spindle Lift by TC and it will eliminate it.
    My Set Up
    1. 285/70/17 w/4.5 Back Spacing
    2. 2.5 SAW Coilovers
    3. Total Chaos UCA
    4. Trimming on the Fenders
    I don't want to invest in the Spindle Lift if its not going to Cure anything. I also don't want to get lifted too much higher than I'm sitting @ now.
    Any insight or advice will be appreciated!
    Thanks in Advance! :D
  2. Oct 20, 2009 at 12:02 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    im kinda leaning towards getting the spindles and dropping down my coilovers an inch or more for softer ride and tire clearance. but I havent bought rims or tires yet. but I think spindles should give you what you need. good luck
  3. Oct 20, 2009 at 12:10 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Camburg's kit is a little cheaper.
    I've been looking into spindles as well, but I'm not sure if that's what I want...
  4. Oct 20, 2009 at 12:16 AM
    RAD
    Rad
    LAX & LOGAN
    I just don't want to drop much more money into the TACO. I love it as is and I've got money go towards things other than the TACO. I just want to be done with modding it.:mad:
    I'm ready to move on to other things but its seems it will not allow me to. :D
  5. Oct 20, 2009 at 12:20 AM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    :rofl: True that.
  6. Oct 20, 2009 at 12:30 AM
    Kenny650
    Kenny650 Well-Known Member
    I've got spindles and I recommend them. I suggest setting your coil overs to a 1" height with the spindles. With this setup, you won't rub at all unless your offroading. I've got this setup now and love it.
  7. Oct 20, 2009 at 12:31 AM
    1BlkT
    1BlkT Mod'n on a Budget
    Ty
    90603
    2006 Black Sport Double Cab
    Allied 4'' Spindles, Sway A Way 2.5 Coilovers, Donahoe Remote Reservoir Shocks w/ Deaver 11Pack Leafs, Goodyear Duratrac 285's, Pro Comp Series 8128, Recessed Grill w/Hella 500's behind, Tint, Black TRD Skid Plate, Debadged, Tailgate Hose Clamp, Weathertech Mats, Aero Turbine 2525XL Exhaust, Volant Intake, RETRO'D Headlights by Yosh2000
    No rubbing on my rig Ray
  8. Oct 20, 2009 at 2:14 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    If you are rubbing, you just need to cut more out of the wheel well. I have 285/70/17 bfg all terrains and 17x9 wheels with 4.5 inch of backspace. Keep in mind my wheels stick out 1/2 inch more than yours. I have no rubbing, but I did cut a lot out and cut my cab mount.
  9. Oct 20, 2009 at 2:17 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    cutting is what he's trying to avoid though
  10. Oct 20, 2009 at 7:16 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Hmmm...$150 (all labor) to get your cab mounts done versus $1,000-$1,400 (depending on brand - tax and install/labor not include) on spindles. I know you said you wanna avoid cutting, but in my mind it's a no brainer!
  11. Oct 20, 2009 at 8:42 AM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    not 4x4.... thats new info
  12. Oct 20, 2009 at 10:10 AM
    jonny
    jonny Betty White Edition Heep ZJ
    i agree
    if you don't wanna go higher than you already are... 3" i am assuming..
    3.5/4" spindle will already exceed your current set up. I am all for spindles on a prerunner. but if you dont wanna go higher and are tired of dumping $$ on the taco....pay the 150 or so to have the cab mounts chopped and plated. plenty of people on here runin around with trimmed cab mounts.
    but that is just my .02
    maybe the spindles and the coilovers on the absolute lowest setting they will go?
    good luck Ray!
  13. Oct 20, 2009 at 10:12 AM
    jonny
    this guy has the perfect set up IMO :thumbsup:
    (my truck is my DD)
  14. Oct 20, 2009 at 1:33 PM
    happyb
    happyb Well-Known Member
    Brandon
    on a beach in hawaii
    to my taste
    making a list
    do you think 305s could fit under that setup with out rubbing?
  15. Oct 20, 2009 at 1:36 PM
    jonny
    if they dont....adjust the 5100's higher. 6.5" of lift at highest setting. (4" spindles+ 5100's @ 2.5):thumbsup:
    havent seen it done w/305's yet
  16. Oct 20, 2009 at 2:10 PM
    happyb
    Brandon
    to my taste
    making a list
    i have been wanting to upgrade for awhile to coilovers and spindles from the ome coils. i really want to run a little wider tire than 285s, 305s look like the next size up but i want to know the minimum amount of lift to get them without major mods.
  17. Oct 20, 2009 at 8:56 PM
    Kenny650
    Doubt it. I had the 5100's at 1.85 and I still had a SLIGHT rubbing at full turn going over a bump.
    .85 with spindles won't be high enough to fit those tires.
  18. Oct 21, 2009 at 8:51 PM
    RAD
    Rad
    LAX & LOGAN
    I've decided after reading and reading about it. I will just get my cab mounts done right. Calling Demello in the morning to inquire about the price and set up a time.
    Thanks Everyone on your Help!
    I'm trying to add my SpiderTrax Wheel Spacers to the Fronts Now. Its on the Rears.
  19. Nov 3, 2009 at 3:49 PM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    You already have 4.5" bs right. Your putting wheels spacers on top of that? And what size spacers 1.25?
  20. Nov 3, 2009 at 4:01 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    i added wheel spacers to eliminate cab mount rubbing issues...well it made it 10x worse...
