Will a Toytec add-a-leaf help with my tacos axle wrap?
Discussion in '1st Gen. Tacomas (1995-2004)' started by HamerMan, Aug 25, 2013.
  1. Aug 25, 2013 at 5:03 PM
    HamerMan
    HamerMan [OP] No brakes on this rape train
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
  2. Aug 25, 2013 at 7:00 PM
    YOTA LOVER
    YOTA LOVER Stay Calm, and Fire For Effect
    NH
    2011 MGM Tacoma DCLB SR5
    A slew of pricey stuff my wife hates me for.
    Should help a little, but you are still building off of the weak oem springs. I recommend a full aftermarket replacement, or look into building a custom set of springs.
  3. Aug 26, 2013 at 7:02 AM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    Does the fact that it's pre-runner with the TRD package make the stock springs any better? If not should I do aftermarket or custom? What's the difference?
  4. Aug 26, 2013 at 7:56 AM
    YOTA LOVER
    NH
    IMO, no. OEM springs are junk. You can search for the "old dog" thread on here and make your own springs from a set of old Chevy springs. He's got a good write up if you are somewhat mechanically inclined, and it'll save you a couple hundred dollars. Aftermarket leafs will be pricier, but you can install them with minimal effort and be done with it.
  5. Aug 26, 2013 at 11:33 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    OMD mod just got mine in :p
  6. Aug 26, 2013 at 11:46 AM
    mudyota
    mudyota Japanese
    eastern NC
    TRD offroad yota
    It actually helped mine some but its still there
  7. Aug 27, 2013 at 11:08 AM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
    Thanks Ill look that up
  8. Aug 27, 2013 at 11:31 AM
    YOTA LOVER
    NH
  9. Aug 27, 2013 at 11:53 AM
    HamerMan
    Andrew
    29 Palms
    '02 prerunner
    Not racetruck
  10. Aug 27, 2013 at 2:28 PM
    wrat
    wrat Well-Known Member
    Wyoming
    2004 Tacoma Xcab 4x4 TRD
    Help, maybe. Remove all axle wrap, no.
    Even after changing to OME Dakars and the OME D6XL (AAL) I still have that snap. However tightening the u-bolts sure helped the most which makes me think what is commonly thought of as axle wrap may just be loose u-bolts.
  11. Aug 27, 2013 at 3:51 PM
    YOTA LOVER
    NH
    You shouldn't have much wrapping at all unless you are running a S/C. Might be some play in the drive line, or you need to lube.
