Will an AAL fix my Axle Wrap???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jwhendrix01, Jul 5, 2014.
  1. Jul 5, 2014 at 6:49 PM
    jwhendrix01
    jwhendrix01 [OP] Well-Known Member
    Gainesville, GA
    I did a thread the other day about replacing my leaf springs due to axle wrap. And also PM a fellow TW member about it and he suggested replacing my leaf springs as well. Well my question to you all is....If I were to get a lift kit that came with an AAL, would that be enough to fix my axle wrap issue? I have a 2006 Access Cab TRD 4x4. Right now all that's done to the suspension is a front spacer which I would get rid of if I were to get a lift kit and replace it with whatever the kit came with. I want the truck to have the leveled look so I don't want any rake at all unless it was very little. Any suggestions for this issue would be appreciated.
  2. Jul 5, 2014 at 7:22 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    I'm no expert but I would say no. It may make it a little better but I wouldn't think it would completely stop it. The stock springs are very weak. I have a replacement set of OME 8 leaf springs waiting to go on for this reason.
  3. Jul 5, 2014 at 7:34 PM
    jwhendrix01
    Gainesville, GA
    That's pretty much what I'm thinking too. But I also don't want to get new springs that are going to lift the rear up alot. I found these earlier http://www.northwestoffroad.com/parts/2stage.php ,the high quality rear replacement springs(Item #N73560), and they say they will only lift the rear about 3/4in more. I can live with that.
