Will an access cab truck cap (6ft) fit flushly with a single cab (6ft)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tortugax626, Jul 10, 2020.
  1. Jul 10, 2020 at 7:28 PM
    Tortugax626
    Tortugax626 [OP] Well-Known Member
    Emilio
    I know you may call me stupid if both cabs are 6ft but I remember reading that an access cab truck cap is a little bit longer than a single cab. I just want someone to confirm whether that’s true or not. I have a single cab and someone is selling an access cab truck cap and I want to make sure there’s no issues. Thank you
  2. Jul 10, 2020 at 7:41 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    I believe the regular cab has a square profile vs the access cab having a curved profile to the back of the cab itself. The caps are different; it should still fit, however the lines won’t match perfectly.
  3. Jul 10, 2020 at 7:52 PM
    Harryhood87
    Harryhood87 Well-Known Member
    Harry
    New England
    2004 Xtra Cab 4x4 Lunar Mist 260k+
    265/75/16, Yak Q towers
    Regular cab cap will fit on access cab but access cab won't fit well on regular cab. The sloping front that matches the slope of the access cab may slowly wear into your paint on the straight upright cab of the regular cab.
  4. Jul 10, 2020 at 8:01 PM
    Tortugax626
    Emilio
    Ok thank you for the response guys
  5. Jul 17, 2020 at 8:18 AM
    brydav
    brydav Well-Known Member
    Bryan
    Austin, TX
    2015 Access Cab TRD SPORT 4x4
    Just got this one - it's a work in progress.....
    I can actually vouch for this. I had a Leer on my 2nd gen access cab. Sold it to someone who had a reg cap. It fit, but the cap ended up touching the cab of the truck - very tight fit up where the cap meets the cab. It was an older truck so they didn't care as long as it fit.
