Will an Exhaust tip make your truck louder?
Discussion in 'Performance and Tuning' started by Vincent, Mar 16, 2009.
  1. Mar 16, 2009 at 7:47 PM
    Vincent
    Vincent [OP] Well-Known Member
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    Exterior: Debadged, color matched White grill surround, Custom Mesh Grill,BHLM,Clear Corners,Tinted Tail lights Black/Clear/Black, Tinted 3rd Brake light 5%tint driver/passenger windows, Limo tint Rear and back windows Interior: Black Leather Door Panels Engine: Deckplate Mod Hayden Transmission Cooler Exhaust: DynoMax Muffler with 2.5 piping after cats Lighting: 6k Headlights,3k Fogs Wheels and Tires: MB Razors wrapped up in 265/70/16 BFGoodrich All Terrain KOs
    I've never had a nice tip put on my truck before...just a bolt on one from pep boys. I want one welded on this time since I had recently put 2.5 inch pipes from the cat back. The truck sounds better to me IMO now.
    so question is. Will the exhaust tip add to MORE sound? or no difference at all?
  2. Mar 16, 2009 at 7:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    No difference...
  3. Mar 17, 2009 at 12:17 AM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    x2 changing your muffler will.:eek:
  4. Mar 17, 2009 at 3:58 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    X3
  5. Mar 17, 2009 at 5:56 AM
    mkeeagle
    mkeeagle Well-Known Member
    Milwaukee, WI
    08 PreRunner
    Bed rug, running boards, window visors, bed cover
    And if you change the windshield washer fluid your blinkers will go faster too. Weird day for me today.....sorry
  6. Mar 17, 2009 at 6:04 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    To add on to that.... if you change your muffler bearings it sounds way better too!!!
  7. Mar 17, 2009 at 6:10 AM
    AFButters
    AFButters Rigger, Please!!
    "Butters"
    Albuquerque, NM
    2008 335xi BMW
  8. Mar 17, 2009 at 6:14 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    On the contrary. An exhaust tip will effect the sound. The length of the tip, size of the inlet/outlet, and whether or not the tip is resonated will have an effect on how the sound rolls out of the exhaust.
    Function Over Fashion
    Exhaust tips actually do play a role in the final sound of an exhaust. Where mufflers and resonators take care of the good majority of exhaust pulse cancellation and silencing, the exhaust tip can shape the remaining pulses and accompanying sound as it makes its final exit from the pipe. Much in the same way a Tuba sounds different than a Trumpet, a short megaphone exhaust tip will sound completely different than a long pencil-shaped exhaust tip. Some exhaust tips even add a small resonator to the equation to help mellow and deepen the exiting exhaust note. A perforated tube surrounded by sound deadening material puts one last mellowing touch on the exhaust pulses before they reach your ears and the ears of others.
    Mounting can also have an effect on sound. A tip that is mounted with a compression clamp or welded on can provide a more solid sound than screw-on type tips. Screw-on tips mount in the same way a light bulb cover bolts onto the ceiling light fixture. Three bolts or screws hold the tip onto the end of the exhaust pipe. Finally, while claims of exhaust tips by themselves adding horsepower are numerous, these claims should be approached with great skepticism. Unless the tip being replaced is acting as a massive restriction to exhaust flow, replacing an exhaust tip is more an exercise in style and sound than noticeable horsepower gains.
  9. Mar 17, 2009 at 6:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hmmm......Not sure Im buying that. Maybe if the tips are shapped like a trumpet or something, but you cant tell me a tip makes an audible difference in SPL. Of all the different tips I have had on an exhaust pipe, not one made a difference in sound.
  10. Mar 17, 2009 at 6:57 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    while it may not necessarily make it louder or quieter, it will 'tune' the note.
    For instance, when you tune your AFR, you may or may not notice any gains, but through specifically designed recording systems (aka a dyno in this case) you can measure the change.. say 2-3hp. The exhaust note is the same way, just much harder to tell unless you have an ear for that kind of thing.
    For instance, if you go from a 6" long 4" oval exhaust tip to a 16" long dual 3" circle tip with built in resonators, i promise you will hear a difference in the tune of the sound not necessarily in DB levels.
  11. Mar 17, 2009 at 7:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....now THAT I belive. Being as the OP asked if they "add more sound", I asumed more DBL's.........
  12. Mar 17, 2009 at 7:09 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    yes, in that perspective you are correct. They generally won't add sound.
    From what I've dealt with in the past, the longer the tip, the smoother the sound. trust me.. the ladies especially love it longer... ;)
  13. Mar 17, 2009 at 7:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
  14. Mar 17, 2009 at 7:13 AM
    Vincent
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    Thanks guys. Now, which tip should i get? i'm thinkin of recycling some cans today hahah and using that money to get a tip.
    i only know about the Slashed, straight, and rolled tips
    which one would lean towards the deepest "tuned" note?
  15. Mar 17, 2009 at 7:22 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    I would suggest a tip 12"-16" long, then based on what look you want oval/round. Choosing one with a resonator built it will mellow the sound, but generally cost more.
    Weld the tip on if you can, you'll get a cleaner sound. :thumbsup:
  16. Mar 17, 2009 at 8:09 AM
    Vincent
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    cool..thanks man, i'll check out the tips today..
    thanks for all the input
  17. Mar 17, 2009 at 8:59 AM
    Vincent
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    i've been calling up shops if they carry a any round/oval Magnaflow resonated muffler tips that are at least 12''-16'' and no one carries them. ( all the shops in my area )
    Does the brand make a difference? cuz i think pepboys might sell the ones i want equipped with a resonator.
  18. Mar 17, 2009 at 9:40 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Your best off finding one online, getting a part number and then call a shop.
    Check out Summit's website. Should be able to find exactly what you need, and for a reasonable price. :thumbsup:
  19. Mar 17, 2009 at 10:07 AM
    Vincent
    Vincent
    Granada Hills
    04 PreRunner V6 2WD
    i just talk to guys from magnaflow and flowmaster.
    Magnaflow said: Tips won't make a change at all and are plainly cosmetic
    Flowmaster said: gave me a novel. and said 40 series flowmaster is the worst sounding muffler available:eek: (honest guy) He also gave me the same lecture as you did (Xrunner) and told me about acoustics and diameter..
    But he couldnt answer my question on whether or not the resonated tips they sell at pepboys would have the same affect as buying one online from Magnaflow for 100+ bucks.
    im so close to getting up and buying a resonated tip from pep boys right now.
  20. Mar 17, 2009 at 10:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Pep Boys stuff is generally lower quality. the ones you may find online may be polished stainless steel, as opposed to cromed rolled steel. Big difference in price...
