Will be pushing soon
Discussion in 'New Members' started by mkm, Apr 9, 2013.
  1. Apr 9, 2013 at 10:53 AM
    mkm
    mkm [OP] Member
    6" suspension lift
    Hello all, I am new to the site and a first time Toyota owner of a 2011 double cab TRD Tacoma. I purchased it from a private seller. It has a 6" Pro Comp suspension lift with Dick Cepek 35x12.50R20s mud tires. Needless to say the gas mileage is horrible. I was wondering what suggetstions yiou may have to help improve it. Smaller tire (all terrain) any chips that would work etc? I purchased a hard cover for the bed as well.
  2. Apr 9, 2013 at 10:54 AM
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    Welcome!!:D
    Would love to see some pics!!
  3. Apr 9, 2013 at 10:55 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Take out that lift and put smaller tires on. That should bring it back up to about 16-18mpg if it's a v6 4x4.
  4. Apr 9, 2013 at 10:57 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    Smaller tires and ditch the lift that will help your gas mileage otherwise there isnt much you can do there are not any chips that work. Taking it easy on the skinny pedal is the only thing that helps a little bit. Also be realistic with what you expect for gas mileage. When you say horrible what are you getting?
  5. Apr 9, 2013 at 10:59 AM
    DBWrecks
    DBWrecks Active Member
    Alex
    Indiana
    1995 Tacoma Xtra Cab
    Welcome!
  6. Apr 9, 2013 at 11:00 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Urd, uconn, apr
    Nevermind......didn't notice ur worried about performance.
    If ur not in the market for hp/tq stay far far away from urd
  7. Apr 9, 2013 at 11:55 AM
    mkm
    mkm [OP] Member
    6" suspension lift
    thought about taking the lift out but after a phone call to the company that put the lift on it could be $2000 to $3000 for this.
  8. Apr 9, 2013 at 11:56 AM
    mkm
    mkm [OP] Member
    6" suspension lift
    Id love to get 16-18mph. I got 11.5 around town
  9. Apr 9, 2013 at 12:02 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  10. Apr 9, 2013 at 12:07 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    Removing a 6" lift ain't easy, or cheap. The factory cross member is cut and replaced, so needless to say, you'll have to replace it with a factory brace.
    Chips wont do shit for it. Smaller tires, smaller lift, and light on the go-pedal.
    My only advice to you is to do some more research next time before buying a truck with that kind of modification. Or at least expect it to get shitty gas mileage and be prepared for it.
  11. Apr 9, 2013 at 2:33 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Something is wrong here....we have the same lift, same year/model truck & 35's....yet my worst mileage is 16.5mpg....I check it all the time. Highway riding .....keeping it under 60mph, I get high 17mpg. In town is 15 to 16's. Worse case ever was towing a 1500lb trailer & I still got 13 to 14.
  12. Apr 10, 2013 at 4:44 AM
    mkm
    mkm [OP] Member
    6" suspension lift
    something is definitely wrong. I towed a trailor this past weekend/ probbaly the same wieght. I got 6mpg!!!! Any ideas where i can start?
  13. Apr 10, 2013 at 4:56 AM
    Warputer
    2011 TRD Off Road
    Start simple.....you do know that your odometer is going to read incorrectly with the bigger tires. So if you are using that to figure gas mileage, it's gonna seem worse. I use a GPS app on a smartphone to get the "actual" milage in between gas fill ups.
    Second, when I drive like a madman, the mileage drops big time (fast acceleration and higher speeds on the Interstate).....it's more in the range of mileage like you are showing.
    Third, how many miles do you have? Could be time a new air filter/plugs.
  14. Apr 10, 2013 at 5:05 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    regear should help
  15. Apr 10, 2013 at 5:30 AM
    mkm
    mkm [OP] Member
    6" suspension lift
    29000 miles. i am a conservitive driver. not hard on it. How much would a regear cost?
  16. Apr 10, 2013 at 5:32 AM
    Warputer
    2011 TRD Off Road
    Manwithoutaplan just did a regear & he has the same lift/tires as us.....send him a message......
    http://www.tacomaworld.com/forum/member.php?u=4500
  17. Apr 10, 2013 at 5:50 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    How are you calculating this mileage? Do you do it for your other vehicles, what are they getting? Fuelly.com is a good way to keep up with your mileage.
  18. Apr 11, 2013 at 8:16 AM
    mkm
    mkm [OP] Member
    6" suspension lift
    I fill the tank until i see fule at the top of the filler. drive X # of miles. Refill the same way and caculate. Does this seem correct?
  19. Apr 11, 2013 at 8:28 AM
    Manwithoutaplan
    ID
    Op i get less MPG then i did before i regeared. But if you have a Auto it might be little better.
  20. Apr 11, 2013 at 9:04 AM
    Warputer
    2011 TRD Off Road
    ...your odometer will not be reading the correct mileage with 35" tires. It will show less miles traveled for each tank......and when you calculate your MPG it will "appear" to be worse than it is.
