Will body lift affect my skid plate fitting?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, May 26, 2012.
  1. May 26, 2012 at 7:03 AM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    NorCal
    2001 TRD 4x4 Xtra Cab
    Tires- 31x15x10.5 Cooper Discovery AT3
    When I bought my truck it has a 1inch body lift and there is no skid on the truck and I was wondering if that 1 inch body lift will affect the placement of my skids or if I have to get custom skid plates to fit it or if their fitting has no change due to the body lift. Thanks for the help
  2. May 26, 2012 at 7:10 AM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    It shouldn't affect it. Im not a 100% on that though. I'm sure someone else here knows
  3. May 26, 2012 at 11:08 AM
    newskooler
    newskooler Well-Known Member
    Nick
    Lake Shastina,ca
    03 Tacoma x-cab TRD SR5
    881/5100 front, 5100 rear, AAL, K&N intake, Diff breather, grey wire mod, tg Low pro and sliders, Custom tube bumper, pinch weld mod, and more... smoked taillights, fabtech tire carrier, sony headunit, 12v always power mod, #70 unhappy clutch spring mod,
    youll be good
  4. May 26, 2012 at 11:11 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    I'm a 2nd gen and maybe I'm retarded but I can't imagine why lifting the body off the frame an inch or two would change mounting points for a skid plate, as those should mount to the frame.
  5. May 26, 2012 at 11:16 AM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    No it will not.
    I have a 3" -soon to be gone- Body lift and it affects it in no way. It is mounted to the underbelly and front crossmember. A BL is installed on top of the cross member.
    The only thing that affects the skid plate location is a front differential drop kit. I have a 1" diff drop that came with spacers for 2 bolt locations. The only part thats not fully secured is the front of the skid plate that is attached to the crossmember
  6. May 26, 2012 at 12:06 PM
    newskooler
    Nick
    Lake Shastina,ca
    Ians right the as long as the front cross member wasnt moved to relocate the bumper youll be good.
  7. May 26, 2012 at 9:53 PM
    Bamahoyt
    Ted
    NorCal
    ok great! thanks for the help guys. I have a Trail gear tube front bumper so I will look into it and make sure that no brackets were moved around or anything.
  8. May 26, 2012 at 9:57 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    PICS OF BUMPER PLEASE!!!
    ...sorry :eek: Im planning on getting one too and would like to see what it looks like on our front end
    How did you modify the trail gear bumper to fit with the body lift?
  9. May 27, 2012 at 12:57 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    OP has existing body lift, not considering adding one.
