Will caps be available for the 2016 right away?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myke232, May 23, 2015.
  1. Dec 22, 2015 at 6:32 PM
    #181
    Chasin Tail
    Chasin Tail Well-Known Member
    Olympia, WA
    2016 Tacoma DCSB 4x Sport MGM
    that looks nice.. Ive had a 100XQ on order for the past 60 days. Last I talked to my dealer he said the factory was waiting on glass to finish the build and gave me an ETA of Jan 8th.
  2. Dec 22, 2015 at 7:18 PM
    #182
    Des
    Des Well-Known Member
    KY
    16 DC OR SB Tacoma Super White
    Yes they are being produced now but not expected to be delivered until around the mid to end of January here in my area. I will probably wait until spring to buy if I get one. I've always had tonneau covers on previous trucks.
  3. Dec 22, 2015 at 8:30 PM
    #183
    CVOTRDSPORT
    CVOTRDSPORT Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    That looks real nice, I like the black glass look. What does that run for a LB?
    Tacopocalypse likes this.
  4. Dec 23, 2015 at 2:05 AM
    #184
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    Found the thread on the gap: https://www.tacomaworld.com/threads/probable-bed-leakage-due-to-truck-bed-gap.400747/
    Answer: Goober RTV in the gap.
    Got it.
  5. Dec 23, 2015 at 2:50 AM
    #185
    2016TacomaTRD
    2016TacomaTRD Part time Ninja
    2016 Tacoma TRD Sport
    very nice!! are the prices out for this topper?
  6. Dec 23, 2015 at 4:30 AM
    #186
    Des
    KY
    My dealer quoted me $1900 to 2500 depending on options for the top model 100XQ on my SB.
  7. Dec 23, 2015 at 4:35 AM
    #187
    2016TacomaTRD
    $1900 doesn't seem that steep, considering they say the 100XQ series are worth the money. Are these things fairly easy to remove when needed or do u need to take it to the shop every time?
  8. Dec 23, 2015 at 4:40 AM
    #188
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    Hey guys how does a cap effect mpg?
  9. Dec 23, 2015 at 4:56 AM
    #189
    Des
    KY
    It weighs around 150-180 pounds so yes you can take it off yourself and 3 of your friends/family to help, also you don't want to set it on the ground directly, you need sawhorses or a stand for it when off the truck.
  10. Dec 23, 2015 at 5:02 AM
    #190
    2016TacomaTRD
    So 150-180 pounds is like having 1 more passenger with you all the time. So maybe mpg is not affected so much. I've already accepted that its not getting the best mpg.
  11. Dec 23, 2015 at 5:02 AM
    #191
    Des
    KY
    It won't improve your mileage, but probably won't deteriorate mpg much. There will be more turbulence at the tailgate area which will theoretically reduce your mpg but as someone else said all that stuff stays dry and secure in the back and it's worth it.
    GravityRulz and gsxxr[QUOTED] like this.
  12. Dec 23, 2015 at 5:08 AM
    #192
    gsxxr
    I have never owned a cap before but I'm starting to really see a lot of use for it now. I have to decide if I like the look or now. I'm still up in the air with that.
    But I think it would be great for my dogs when I go hiking and places.
  13. Dec 23, 2015 at 6:03 AM
    #193
    Des
    KY
  14. Dec 23, 2015 at 6:27 AM
    #194
    gsxxr
    Yeah I just saw that.
    That's a nice cap.
  15. Dec 23, 2015 at 8:55 AM
    #195
    GravityRulz
    GravityRulz Active Member
    Regarding the leaks...I checked out a truck on the lot yesterday and remembered when I was chasing leaks on my old tonneau cover. Those plastic covers the OEMs put on the bed rails were a problem. I had a solid seal on parts of my cover and water got through by blowing underneath the rail covers. They're far from a perfect fit and when the weight of the cap is distributed out, there isn't enough PSI to push down the hard plastic. Folks might want to look at removing them before installing their cap. Maybe having a Line-X cap sprayed on first to protect the mating surface.
  16. Dec 23, 2015 at 3:11 PM
    #196
    edummann
    edummann Well-Known Member
    Eric
    Bend, Oregon
    I have to tell you I really did not like the look of my truck with the cap at first, but it was well worth it. It was awesome for keeping my stuff safe and dry. Plus it was awesome for my dog! I got pet screens on mine, and that also added a bit of security for when the windows were open on it. After a while I began to like the look.
    gsxxr[QUOTED] likes this.
  17. Dec 23, 2015 at 7:30 PM
    #197
    Tacopocalypse
    Tacopocalypse Well-Known Member
    As someone who bought an ARE V series with side window-doors for work, and because I like the rugged look of the utilitarian doors and handles, I must say, the Leer pictured above with the more "SUV style" look, looks much better than the equivalent ARE Z series, and at $1900 seems much more affordable than the similar SUV style ARE topper.
    That being said, toppers do have many advantages, and very few disadvantages from my experience. I have had a 2012 Double Cab Short bed, and now a 2016 DCSB, both with toppers, and the only downside i can find to not having a topper, is that i can't have a skid loader or tractor dump mulch or compost right into the bed. But, especially with a short bed, i can usually just hand shovel it full with mulch of whatever without too much work. A few 8 foot sheets of drywall, plywood, or 2x4s etc can just sit on the closed tailgate and wheel wells with the topper door closed and really no need for tie downs, even with the short bed. Being able to lock up the contents of your bed, even if it is completely full to the ceiling of the topper, is VERY CONVENIENT. Without an interior topper liner or carpeting, you can just park it so the tailgate faces downhill, and spray it out with a hose, and it will come basically completely clean. More storage space and a level space on top to the topper for ladders, etc.
  18. Dec 23, 2015 at 7:38 PM
    #198
    gsxxr
    Thanks guys for all the advice on the topper and not flaming me.
  19. Dec 23, 2015 at 7:45 PM
    #199
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Kind of hard putting a refrigerator, washer, and dryer in the back with a truck cap on. Full size mattress set sucks trying to put in the bed also. If a guy had a trailer hitch all would be good in the world. U-Haul is always close by to rent a trailer.
    gsxxr likes this.
  20. Dec 24, 2015 at 6:07 AM
    #200
    Des
    KY
    I have an application question about a topper on the SB taco, I love going to a couple different fishing spots locally with my kayak. The kayak is 12 ft long and I can haul it pretty easily in my SB with a load extender support installed in the hitch receiver. I was thinking of getting a topper with a rack, either yakima or thule depending on the brand of topper. The question is on the SB the rails would only be about 4-4 1/2 ft apart and with a 12 ft kayak that may not work very well going down the road. Anyone with any experience using these rails on the SB with longer objects; ladders, kayaks, or whatever?
