Will constantly turning my engine off and on shorten its life?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Jan 16, 2020.
  1. Jan 16, 2020 at 9:16 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello I just got a part time night job collection trash in my truck so I'm constantly turning off and on my truck. Will this shorten the life of my engine? It's a 3.4 auto
  2. Jan 16, 2020 at 9:25 PM
    Bishop84
    Bishop84 Well-Known Member
    Just shorten up the oil change intervals, at the end of the shift do you have a longer drive home? A good romp on a highway is the best way to burn off the carbon and water in the engine.
    A fuel cleaning agent in a tank wouldn't hurt to fight carbon build up in the engine.
    3.4 is stout, you'll be ok.
    eon_blue likes this.
  3. Jan 16, 2020 at 9:46 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Sometimes the work in 30 minutes away and sometimes 10 minutes away but I do add marval mystery oil to my gas tank and have a oil addative added to my engine oil
  4. Jan 16, 2020 at 9:47 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Would every 3k miles be ok ?
    GQ7227 likes this.
  5. Jan 16, 2020 at 9:48 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    Might kill your alternator before it kills your engine. All that work all the time starting the truck...
  6. Jan 16, 2020 at 9:50 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    Should I just leave it running instead?
    GQ7227 likes this.
  7. Jan 16, 2020 at 9:51 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Depends on how long you were to leave it idling. Starters and alternators are relatively cheap and easy to replace.
  8. Jan 16, 2020 at 9:52 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    About 5 hours
  9. Jan 16, 2020 at 9:54 PM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    I'd definitely turn it off. Sitting for 5hrs at a time isnt gonna kill anything. I was thinking you were making dozens of little stops all night long. On off on off on off. That sort of thing.
    joe25rs likes this.
  10. Jan 16, 2020 at 10:05 PM
    Tacomaislife
    Texas
    2002 tacoma trd
  11. Jan 16, 2020 at 10:07 PM
    Tacomaislife
    Texas
    2002 tacoma trd
    I do make dozens of little stops my shift is about 5 hours so if I don't turn it off and on it would just be running my whole 5 hour shift
  12. Jan 16, 2020 at 10:08 PM
    Tacomaislife
    Texas
    2002 tacoma trd
  13. Jan 17, 2020 at 5:47 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    make sure you get a few extra spare keys made so you can lock your truck if you feel the need to get out and leave it running in a possible sketchy area of town, don't want someone hopping in and driving away with it!
  14. Jan 17, 2020 at 7:22 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    This is definitely one of those "just my opinion" threads, so here is mine.
    If your cooling system is clean and you have good oil pressure, idling won't harm your engine. You could compare it to people sitting in stop and go traffic every single day as commuters.
    It may result in your spark plugs getting dirty sooner.
    Of course, every revolution is a tiny, tiny, tiny bit of wear, but will it ever catch up with you....
    I'd make sure you watch the coolant temp (scan guage?).
    If you do shut it off each time, I'd get one of these to keep an eye on your charging/battery condition.
    https://www.amazon.com/dp/B07C5H7VPT/ref=dp_cerb_1
    cruiserguy likes this.
  15. Jan 17, 2020 at 8:21 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    The OP should consider getting one of those little magnetic boxes and stick your spare key inside. Then put the box on top of the frame rail near the driver's door. I do a lot of off-roading in remote areas, over roots, rocks, and ruts, and the magnetic box never moves.
    TheFang and 2002Tacoma4x4 like this.
  16. Jan 17, 2020 at 1:02 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    The company I work for has a fleet of a couple thousand Toyota forklifts with 4Y engines in them and we actually saw reduced starter replacements when we mandated they be turned off any time an operator was not in the seat. Zero downside and 100% upside with reduced fuel consumption, reduced maintenance costs, and improved safety in the event the unit was left in gear.
    underaroof likes this.
