will dej cannons fit on my 2002 tacoma
Discussion in 'Wheels & Tires' started by isonhood84, Feb 9, 2011.
  1. Feb 9, 2011 at 9:28 PM
    isonhood84
    isonhood84 [OP] Member
    02 tacoma
    cold air intake, 5 inch tuff country lift.
    I am trying to figure out if the dej cannon wheels will fit on my tacoma. I know that tacoma and chevy have the same bolt pattern 6x5.5, but a stock chevy wheel won't fit on a tacoma due to the smaller center hole. Has anyone every seen or know if the cannons will fit?
  2. Feb 10, 2011 at 5:40 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Welcome to TW.
    Need some more specifics on the wheel in order to help you.
    Wheel diameter, width, backspacing or offset, hub centric?, hub bore size, etc.
  3. Feb 10, 2011 at 6:52 AM
    isonhood84
    02 tacoma
    The wheels are 17x8.5 with -6 offset and 4.5 backspacing, from what i know it is lug centric. i am not sure of the rim bore size can't find it anywhere
  4. Feb 10, 2011 at 7:01 AM
    KPT
    09 Prerunner
    Those specs are perfect.
    Worst-case scenario, you have a shop bore them out if the hub bore is too small.
  5. Feb 10, 2011 at 11:01 AM
    isonhood84
    02 tacoma
    thanks for the help.
