Will extended periods with no power cause the trans to go into "learning mode" again?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wadeo, Aug 9, 2016.
  1. Aug 9, 2016 at 10:19 AM
    wadeo
    wadeo [OP] Well-Known Member
    Harrisburg, PA
    2018 TRD OR DCSB 4x4 BBP
    I was installing some audio equipment last evening and had the battery disconnected for several hours. It almost seems like it drives differently now that I've done that. I'm wondering if the trans is back in learning mode or if you have to actually do something with the software to reset the trans into "learning mode."
    My first thought is that it is back into learning mode as I wouldn't know where it'd be getting power to store the previously learned driving habits, but I'm no expert.
    I ask because I babied the truck when I first got it and the trans was learning. I got the software update and drove it more aggressively than I typically drive and really, really liked the difference vs the "babying" learned habits. I'm just wondering if I need to teach it to be aggressive again.
    Thanks ahead of time!
  2. Aug 9, 2016 at 10:21 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    the answer is yes
    you need to drive 'the pattern' again for it to learn to like how your foot pushes the gas
    and it will adjust shift points and lockup
    wadeo[OP] likes this.
  3. Aug 9, 2016 at 3:20 PM
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    So you are saying that if you took it easy on the go pedal during break in the transmission will always keep this pattern until you do a reset? How long does the battery need to be disconnected to get transmission into this reset mode?
  4. Aug 9, 2016 at 3:21 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I don't think anyone has the facts on how the system actually responds or learns according to specific stimuli. All we can do is assume or speculate
  5. Aug 9, 2016 at 4:19 PM
    VaGlock
    Kevin
    central virginia
    Thanks, I am sure the dealer will not give up the info we need.
  6. Aug 9, 2016 at 4:27 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I don't have a 3rd generation but my guess would be that it's always learning. If I were the programmer I would look at data from the last X number of events. Let's say you were light on the gas for many miles then hooked up a trailer or loaded it up with bags of sand. Or if you drove through Kanas then went through the Rockies. It should compensate shortly after doing that.
    Garyji and smitty99 like this.
  7. Aug 9, 2016 at 4:54 PM
    VaGlock
    Kevin
    central virginia
    That makes sense, lets hope they had the sense.
  8. Aug 9, 2016 at 5:10 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    as far as i am concerned i am learning to deal with it, ie ECT button is getting worn out. that's the only learning going on ....
    smitty99[QUOTED] likes this.
  9. Aug 9, 2016 at 5:23 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    right. it is true it learns...
    but exactly how is not really published by toyota anywhere
    and it varies by code revision
  10. Aug 10, 2016 at 3:17 PM
    EJ257
    EJ257 Master Baiter
    NY
    2016 TRD OR DCSB 6M/T | 2005 Subaru WRX STi
    If all power runs out from the vehicles engine control module, it will reset, therefore forgetting whatever learned values were stored.
    My Subaru, for example, has to relearn fueling and ignition advance adjustments when I clear a DTC with my laptop. Just drive it for a while, and it'll go back to normal.
