Will FJ Cruiser rear discs fit my Prerunner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRSAndrew, Sep 8, 2014.
  1. Sep 8, 2014 at 12:49 PM
    LiquidDragon
    LiquidDragon Well-Known Member
    Michael
    Williamsburg, Va but now in the Philippines
    2021 Toyota Hilux Conquest 4x2
    none yet
    Nah I think the titles would just be different and say something like Check out this sweet disc brake conversion that I found for my Tacoma. :D
  2. Sep 8, 2014 at 1:38 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OK to answer..... your options are limited and very expensive for nothing gained.
  3. Sep 8, 2014 at 1:51 PM
    LiquidDragon
    Michael
    none yet
    BTW its a little more expensive than the first kit that I linked but looks like a bad azz kit and would get you the disc brakes that you want.
    http://www.tundraracing.com/proseriesprerunner.htm
  4. Sep 8, 2014 at 2:04 PM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Yes it would. Combination disc/drums have a proportioning valve built in that sends a different amount of pressure to the rear drums. Sometimes this valve is built into the master cylinder, and sometimes it's mounted in the brake line itself.
    For years street rodders have been using adjustable proportioning valves made by companies like ECI.
    I can only imagine the headaches that would go along with trying to get ABS working and talking to the onboard computer.
  5. Sep 8, 2014 at 2:08 PM
    LiquidDragon
    Michael
    none yet
    That is why its best to go with a kit that is built specifically for our truck instead of trying to make something work.
    This is from the website that makes disc brakes for our trucks
    This kit is designed to replace the original equipment rear drum brake system on all
    2005-2015 Toyota Tacoma 4x4 &PreRunner.
    Compatible with factory ABS & master cylinder.
    It should be installed by a qualified automotive brake system technician.
    Rotors choices include plain, drilled only, slotted only or slotted & drilled combo.
  6. Sep 8, 2014 at 10:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    How often are you having to rebuild the drum brakes? I normally get 100K miles + from a set of rear drum brakes.
  7. Mar 22, 2015 at 9:56 PM
    boto
    boto Active Member
    Philip
    Quebec/Canada
    07 taco dbl.cab.long bed TRD
    fog anytime bhlm royal purple oil kn&n oil/air filter secondary filter removed ultimate lift kit toytech 3 inch coilovers ans add a leaf relentless fab diy bumper
    What if we dont want a 900$ solution .and if we want an easy way to replace brake pads and rotors with only a fj kit and not a custom kit .i hate drums on my 07 tacoma it never locked any of the rear wheel and they always get full of mud and crap and they look awfull
    Dirtridercrf250 likes this.
  8. Mar 22, 2015 at 10:04 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    Mr. Mod Mike use this kit?
    http://www.tacomaworld.com/forum/2nd-gen-builds/17641-mjp2s-build.html
    search disc on the first page (control f it) and you will see where he talks about it.
  9. Mar 22, 2015 at 10:22 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    Yeah, every time this comes up someone else has failed to make the swap work. I mean work better than stock. This isn't like an old Honda where the OEM made two versions of the braking system compatible for manufacturing purposes and a quick swap of the MC and proportioning valve made everything work 100 percent. This is much more complicated because of ABS and the lack of any clear donor vehicle for the new parts that will work 100 percent with the old ones.
    I hate to say it but if form over function is your thing it might be time for a new truck that isn't the Tacoma. GM makes a pretty truck with rear discs.
  10. Mar 23, 2015 at 8:20 AM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    that's a good looking kit; and seems really complete down to e brake functionality.
    seems like, somewhere in the wide world, there ought to be a plate adapter to get existing toyota parts on the trucj. I haven't looked into though.
    If I were towing big weight a lot, discs might seem more necessary, but for now, the drums seem fine, and I don't think I even had to replace shoes on my last Toyota pickup in 200,000 miles...
  11. Mar 23, 2015 at 10:00 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    My 00 stang rear brakes look awfully similar to that first kit.
