Will front diff from 98 4runner fit my 98 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by stygzy, Jul 17, 2023.
  1. Jul 17, 2023 at 7:41 AM
    stygzy
    stygzy [OP] Member
    Colorado
    1998 White Tacoma TRD 3.4L manual.+ 31s and a. 3in lift.
    Cd/DVD touchscreen radio with a backup camera, obnoxious ahhooga horn, diamond plate toolbox, and 2 hard plastic saddlebags.
    So I've been lurking here for years and this forum has been a great source of info for my truck. I have a 98 Tacoma I've had for 20+ years. My front diff is was shredded when a gallon of milk knocked it out of 4 wheel high while I was still moving so it's done. I have a doner 98 4runner that has the same 3.4 5vz fe. I was wondering if the front diff is compatible. It looks the same but I haven't been able to find much info online.
  2. Jul 17, 2023 at 1:00 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Should be fine as long as the gear ratio, and actuators are the same (either vacuum or electric).
  3. Jul 17, 2023 at 3:02 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I shift out of 4 High all the time while driving just how did that hurt your front differential?
    ztwatson and vern650 like this.
  4. Jul 17, 2023 at 4:06 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Agree with above, I don’t see how bumping it into two wheel from 4 hi is going to hurt your diff. Pretty sure trucks with the auto hubs are shift on the fly, and even manual hub trucks the tcase will shift on the fly if the hubs are locked in and everything is spinning the same speed. I do it all the time.
    Bivouac likes this.
  5. Jul 17, 2023 at 7:52 PM
    Bivouac
    I have shifted out of 4 high with every 4x4 I had since the first one in the seventies.
    Trying to shift into 4 High with manual hubs while driving is different makes loud uncomfortable noise but you would have to keep forcing things to do real damage.
  6. Jul 18, 2023 at 6:39 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Unless you franken-built your transfer case and its missing the synchronizer ring :hattip:
    and then it becomes -
    STOP,
    PARK,
    SHIFT,
    GO
    :rofl:
    vern650[QUOTED] likes this.
  7. Jul 18, 2023 at 7:32 AM
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    What the hell type of milk gallon is hitting your diff so hard it unlocks the hubs?
    ztwatson likes this.
  8. Jul 18, 2023 at 4:08 PM
    vern650
    brandon
    hyrum, ut
    I don’t have any issues with my hubs locked in as long as I’m moving and all the tires are turning the same speed, either going in or out of 4hi, but once I was in la la land cruising down the road with hubs unlocked and for whatever reason pulled the tcase lever towards 4hi and boy howdy did she sing. Snapped out of my stuper real quick.
  9. Jul 18, 2023 at 5:12 PM
    Bivouac
    I meant manual Hubs being unlocked .
    No biggie !
