Will Gen 3 Tow Better than Gen 1?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoDude3391, Sep 20, 2016.
  1. Sep 20, 2016 at 1:04 PM
    TacoDude3391
    TacoDude3391 [OP] Active Member
    So I have a gen 1 manual. Unlike the new 3.5 is actually has good low-end pull but that evaporates quickly after 50-60 mph.
    The gen 3 3.5L has quite a bit more HP and torque but if you crunch the numbers, the power to weight ratio of the gen 3 isn't far off from the gen 1 because the gen 1 is so light.
    Will a gen 3 even tow my 3,000 lb pop-up any better than my 2001 I own now?
    ChadsPride likes this.
  2. Sep 20, 2016 at 1:06 PM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
  3. Sep 20, 2016 at 1:11 PM
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    I believe that the 1st gen's V6 only put out 190hp. Even with a heavier vehicle, 276hp is a big step up.
    I know horsepower isn't the only factor, but I don't know the torque numbers off the top of my head.
  4. Sep 20, 2016 at 1:11 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Our 16 tows very well. You "almost" can't feel it compared to our Gen1 Double cab, which runs out of breath.
    ChadsPride and arnette64 like this.
  5. Sep 20, 2016 at 1:15 PM
    gregt909
    gregt909 Well-Known Member
    Greg
    Austin Texas
    2016 Tacoma Sport
    Has plenty of power for towing 5000lbs+. I turn on the ECT switch to keep the engine in a happier rpm range so it's not lugging the engine. I think of it as a tow/haul switch on other brands.
  6. Sep 20, 2016 at 1:16 PM
    Lovci
    Lovci Well-Known Member
    2017 White Tacoma SR AC 4cyl M/T
    Well if you have a manual 3rd gen it's certainly no comparison. Probably isn't even with the auto.
  7. Sep 20, 2016 at 1:25 PM
    TacoDude3391
    From I have heard the manual will out-tow the auto because of the rear-end gearing.
  8. Sep 20, 2016 at 1:26 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    I tow a 4800lb boat. It does pretty well with it.
  9. Sep 20, 2016 at 1:27 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
  10. Sep 20, 2016 at 1:38 PM
    TacoDude3391
    Funny I see people saying their truck tows 5000lbs good and some say it absolutely sucks. I live in Colorado I can imagine towing in Colorado is a whole different ball game than towing in Florida. I appreciate the responses however.
    gregt909 likes this.
  11. Sep 20, 2016 at 1:40 PM
    flatus
    biloxi,ms
    I do tow on flat terrain most of the time.
  12. Sep 20, 2016 at 1:42 PM
    Metalhead514
    Metalhead514 Darth Taco
    Nate
    Washington State
    '16 TRD Off Road
    MBRP catback, Magnuson TVS 1900 Supercharger, Injen Evolution intake, Race Louvers RST hood vent, Avid front and rear guards and side steps, Cali raised front/ rear LED's, TRD Pro Skid plate, custom aux fuse box, Bak Flip tonneau.
    It is absolutely different. I towed a bunch of tools recently and the loaded trailer was maybe 2,000 lbs. Flat ground, I didn't feel a thing. However, when I got to the mountain passes, I could feel her running out of air. My #1 goal for modding my 3rd gen TRD OR is adding a supercharger to help with the air at higher altitude.
  13. Sep 20, 2016 at 1:46 PM
    gregt909
    Greg
    Austin Texas
    2016 Tacoma Sport
    It's a matter of perspective. Does it tow as well as an F150 with a V8 or turbo charged V6? No. But it's a midsize truck with a naturally aspired V6 that probably gets 5 mpg+ better than the F150.
    Imo: it tows well even uphill but expect to be in the 4-5K rpm range when towing some serious weight and trying to keep up with traffic.
  14. Sep 20, 2016 at 1:51 PM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    I wouldn't go go as far as saying 5 mpg better than the f-150. Almost every engine in the F-150 with the exception of the base 3.5 (non-turbo) will get similar MPG as the Tacoma unloaded and will probably get better MPG while towing since the EcoBoosts run at low RPM. In many cases bigger V8's get better towing MPG than smaller V6's because a V6 has to rev high and breathes less efficiently as those RPM's.
  15. Sep 20, 2016 at 2:01 PM
    gregt909
    Greg
    Austin Texas
    2016 Tacoma Sport
    All I can report to is unloaded mpg. I had a 2013 F150 with an ECO Boost V6. Got 15-17 mpg mixed driving. Getting 22 same mixed driving with my Tacoma. Towing 5000lbs with the ECO was 12-13 driving across Texas (mainly flat). Can't report on the Tacoma's mpg as I haven't towed for a long distance to compare.
  16. Sep 20, 2016 at 2:01 PM
    Metalhead514
    Nate
    Washington State
    '16 TRD Off Road
    Toyota needs to pull their heads out of their asses and drop that 5.7 into a Taco. If Dodge could do it, they can.
    gregt909[QUOTED] likes this.
  17. Sep 20, 2016 at 2:05 PM
    gregt909
    Greg
    Austin Texas
    2016 Tacoma Sport
    It would do wheelies taking off from a stop light with that setup.
  18. Sep 20, 2016 at 2:07 PM
    TacoJonn
    Jon
    Laramie, Wyoming
  19. Sep 20, 2016 at 2:10 PM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    LOL a stock 3.4 loaded down has trouble doing grades while holding 55mph, a 2nd or 3rd gen can accelerate up those grades
    TacoJonn likes this.
  20. Sep 20, 2016 at 2:28 PM
    TacoJonn
    Jon
    Laramie, Wyoming
    My gen 1 tows my Casita (2500lb dry weight, see my prof image) fairly well on flat land but yeah, all bets off on any sort of grade. I wouldn't feel comfortable towing my Casita over I-70 west of Denver because of the traffic.
