Will Goodyear Duratrac 265/75/16R fit my truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by awkoch, Aug 19, 2011.
  1. Aug 19, 2011 at 10:21 AM
    awkoch
    awkoch [OP] Active Member
    Andrew
    Oceanside, CA
    2004 TRD Off-Road Tacoma 4x4
    Hey guys - new to TW, and trying to figure out what will work on my new Tacoma. I have a 2011 Access Cab TRD-OR, completely stock. I'm thinking about getting Bilstein 5100s all around, set to 2.5 in the front with a rear AAL. If I put on a set of 265/75/16R Duratracs with the stock OR wheels, will I have any problems with rubbing? Also thinking about gettnig small wheel spacers for a more aggressive look - what size would you recmomend? Thanks for the input.
  2. Aug 19, 2011 at 10:35 AM
    awkoch
    Andrew
    Oceanside, CA
    Nice, thanks for the quick reply. What about 285/75?
  3. Aug 19, 2011 at 10:38 AM
    fishntaco
    fishntaco Well-Known Member
    Josh
    Mobile Al
    08 Silver Streak DCLB Prerunner Sport
    You'll need wheel spacers and you'll have to trim. Possibly a body mount chop too.
  4. Aug 19, 2011 at 12:13 PM
    PVT Pablo
    PVT Pablo Ultra Junior Member
    Paul
    Chesapeake, VA
    2016 4Runner TRD Pro
    Just put 285/70/17 DuraTracs on my truck with a 3'' ProComp lift. No mount chop required. I did however have to take off the front mud flaps.
  5. Aug 19, 2011 at 12:27 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    265's should be fine with no chopping, from what I understand, if you add spacers to them you will rub, but I cant confirm that from experience. 285 should fit with minor trimming, again adding a spacer could make that worse...
  6. Aug 19, 2011 at 12:29 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    You have to add a spacer to the stock wheels to run 285's
  7. Aug 19, 2011 at 12:34 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    Hampton, VA
    '17 Tundra; '16 Odyssey; ;14 A4
    x12345789
  8. Aug 19, 2011 at 12:40 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Not really, you have to run wheel spacers if you are running OEM wheels. The back spacing isn't enough on them. Now if you plan on running other wheels, 4.5 BS is the way to go. I'm basing this off of running 285s. I run 285s with a 4.5 BS wheel. My inner fender wells touch my tires sometimes but I was able to reduce the rubbing so much that the only time I notice any rubbing is at full turn. Also you need spacers to clear the UCA (when running OEM wheels)
    Now on the other hand, when running 265s you don't need (spacers) you might rub against the front mud flaps... That can easily be fixed with them being removed. Personally I think the truck looks better with them off, and no real noticeable damage has been done to the paint.
  9. Aug 19, 2011 at 12:40 PM
    krimson
    krimson Nothin
    TRD Off Road
    xOZ-T
  10. Aug 19, 2011 at 1:22 PM
    Icepuck72
    Icepuck72 Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Yes, they will fit. Just put these on today. No lift. 16X7.5 FJ rims. Pics in this link.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/172147-my-precious-has-arrived.html
  11. Aug 19, 2011 at 5:25 PM
    09WhiteTaco4x4
    09WhiteTaco4x4 Well-Known Member
    Washington
    2009 4x4 TRD Off-Road DC
    Removed mud flaps, Borla cat-back exhaust, AFE Pro-Dry S air filter
    I think you meant to say that the backspacing is too much with the OEM wheel. ;)
  12. Aug 19, 2011 at 5:52 PM
    krimson
    krimson Nothin
    TRD Off Road
    :spy:
  13. Aug 22, 2011 at 5:53 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    I have 265 70 R17 duratracs on procomp 7033's. I have a 2" ome lift and i still had to remove my front mud flaps. I'm not sure what the bs is. The tires do look killer though. We tried putting 33's on but there would have been some serious chopping going on.
  14. May 25, 2013 at 12:49 PM
    arturo lopez
    arturo lopez Member
    ElPaso,TX
    04 s runner double cab
    HI, I CURRENTLY OWN A 04 TACOMA DOUBLECAB PRERUNNER. AND I WANT TO KNOW IF I CAN FIT SOME GOODYEAR DURTRAC TIRES ON A STOCK PRERUNNER. OR DO HAVE TO USE LIFTKIT.
  15. May 25, 2013 at 1:57 PM
    DoorDing
    DoorDing The game is afoot.
    Sussex Downs
    Hansom cab
    No.
    2012 DCSB Off-Road
    OEM 16" wheels
    265/75-16 C Goodyear Wrangler DuraTrac tires
    OEM suspension
  16. May 25, 2013 at 2:18 PM
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
  17. May 25, 2013 at 5:01 PM
    Seer
    Seer Well-Known Member
    Tom
    Bayfield, CO
    13 Double Cab 4x4 stock
    Those tires look real nice on a stock Taco. Did they change your mileage any?
  18. May 25, 2013 at 5:21 PM
    DoorDing
    Sussex Downs
    Hansom cab
    Thanks. I haven't had them on long enough to see how they impact fuel economy, but they aren't that much bigger or heavier than stock. They're also surprisingly quiet for that aggressive of tread.
  19. May 25, 2013 at 5:29 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    have them on my truck, with ~2.5" of lift, size 265/75/16, and i love them.
  20. May 25, 2013 at 5:39 PM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    This was a pic with 265/75/16 GY DuraTrac before lift. No rubbing and all mudflaps still on.
