will i be able to...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bfoster133, Jun 21, 2011.
  1. Jun 21, 2011 at 10:33 PM
    Bfoster133
    Bfoster133 [OP] If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    will i be able to clear 33's with stock rims and 5100's set at 2.5" and 1.5" AAL?
    i understand some trimming will be needed, and rub a little on the frame.. the search doesnt work for me and googling the answers quite tuff with so many questions on TW
    thanks in advance :wave:
  2. Jun 21, 2011 at 10:36 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    you'll need new wheels with a deeper backspacing like 4.5" or less or you can run wheel spacers like SpiderTrax in a 1.25" size...as far as the height goes it will be fine but it WILL require some minor trimming....there's TONS of threads about this if you use the "search" function...good luck and post pics ehen you get it all installed :cool:
  3. Jun 21, 2011 at 10:37 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
  4. Jun 21, 2011 at 10:38 PM
    ColtsTRD
    Scott
    AZ
    hahaha just read how you searched already so sorry bout that :p
  5. Jun 21, 2011 at 11:10 PM
    Bfoster133
    Blake
    any reason as to why?
  6. Jun 21, 2011 at 11:12 PM
    rcfreak201
    rcfreak201 Well-Known Member
    yeah u can clear 33s with a 2.5" lift, you'll rub a bit but should be fine for the most part, i ran a 2.5" spacer with 285s with 4.5 backspacing on my rims and it was fine. the rear was stock and cleared the 285 so you should have no problem with the AAL. go for it:cool:
  7. Jun 21, 2011 at 11:15 PM
    BlueTaco07
    BlueTaco07 Super Mod!
    Cody
    Panama city, Florida
    Looking
    Because the 285 will rub your uca's you can get rims or spidertraxxx wheel spacers to clear
  8. Jun 21, 2011 at 11:15 PM
    BMOC
    Paden
    Phoenix, AZ
    like they said, you'll rub without any spacing.
    even with it you'll still have to trim inner fender wells and more than likely have to hammer the pinch weld and chop the cab mount.
  9. Jun 21, 2011 at 11:16 PM
    rcfreak201
    mine never rubbed, oh also when i got spidertrax just cuz i wanted to be wider, it rubbed alot more but i never had uca rub, just on the plastics and flares
  10. Jun 21, 2011 at 11:17 PM
    BlueTaco07
    Cody
    Looking
    You'll clear them with minimal trimming however the back of the tire will not clear the uca. Thats why they are say a 4.5 bs so it moves the tire out more away from the uca's
  11. Jun 21, 2011 at 11:17 PM
    BlueTaco07
    Cody
    Looking
    Were you running 285/75 or 285/70?
  12. Jun 21, 2011 at 11:18 PM
    rcfreak201
    edit: so is 70 narrower than the 75? i never really understood the middle number
  13. Jun 21, 2011 at 11:19 PM
    Bfoster133
    Blake
    so you had no spacers and no rub on your uca correct?
  14. Jun 21, 2011 at 11:20 PM
    rcfreak201
    ^correct, i only had rub on the flares and plastics and on the cab mount because i never had it chopped but i clearly remember never rubbing the uca because i was concerned about that
    and then i added spidertrax for a wider stance and rubbed on the sides more lol it was weird but yeah no uca rub forsure
  15. Jun 21, 2011 at 11:21 PM
    BlueTaco07
    Cody
    Looking
    Thats werid... Stock rim right?
  16. Jun 21, 2011 at 11:22 PM
    BMOC
    Paden
    Phoenix, AZ
    it's not necessarily wider, just the aspect ratio you have to calculate with if i'm not mistaken.
  17. Jun 21, 2011 at 11:23 PM
    rcfreak201
    nope, pro comp 7089s, i still check my ucas once in a while but i see no sign of rubbage haha
    specs are
    16x8
    4.5 backspacing and 0 offset
  18. Jun 21, 2011 at 11:25 PM
    BMOC
    Paden
    Phoenix, AZ
    he's using stock rims though!! it'z crazy i tell ya!!
  19. Jun 21, 2011 at 11:28 PM
    rcfreak201
    ohh! ok nevermind then i have no idea if you can clear your uca with stock rims hahah i have just shitted in this thread, unsubbed! :D
  20. Jun 21, 2011 at 11:32 PM
    BlueTaco07
    Cody
    Looking
    Okay OP disregard Rcfreak as he wasnt payng attention. You will clear with minimal trimming. However since you have the stock rims you wont clear the uca so you need to either get wheel spacers or a new set of rims with a 4.5 bs or less.
