will i be doing this right?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BSP4x4, Dec 26, 2009.
  1. Dec 26, 2009 at 10:25 AM
    BSP4x4
    BSP4x4 [OP] Guest
    If one were to drain the tranny (Manual) and refill with syn oil (MT90).
    Would you just unscrew the fill/check plug, measure how high the oil is with your finger, unscrew the drain plug, drain the dino oil, screw the drain plug back in, refill with MT90 up to the same spot you measured with your finer?
    sound about right?
  2. Dec 26, 2009 at 10:27 AM
    "OldManTan"
    "OldManTan" Now my Taco is bloody Red, ewww
    Buffalo, NY
    08 Access Cab, Radiant Red
    Pioneer HU, Duratracs on Black stockers, Century topper with custom electronic lock, Illuminated 4x4 switch, Foglight Mod, Always on 12v Plugs, Sub & Amp, LED Interior Lights, Cup Holder Mod, Andres Devil Horns, CB radio, steps, relocated trailer harness, blacked out everything!!
    No but yes. You fill it til it comes out the fill hole. Mind you the truck must be on level ground. It takes 2.3 qts I think.
  3. Dec 26, 2009 at 10:28 AM
    BSP4x4
    BSP4x4 [OP] Guest
    great! will i notice any MPG difference by switching the engine and tranny oil over to Synth? I'll be using mobile 1 for the engine
  4. Dec 26, 2009 at 10:29 AM
    "OldManTan"
    Buffalo, NY
  5. Dec 26, 2009 at 10:32 AM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    Just fill it up until the oil comes out the fill plug. let it settle to a slight trickle and then cap it off and torque the fill and drain plugs to spec.
    Make sure you are on level ground before you attempt the service. Also, remove the FILL plug first!
  6. Dec 26, 2009 at 10:34 AM
    "OldManTan"
    Buffalo, NY
    You may notice a little improvement. I ran synthetic in my last 2 chevys. I find that you develop leaks easier. I read once its due to the fact its thinner. Not sure about that. Never did a mpg check on the engine oil. Putting it in the diffs seemed to help though. I have switched my tranny, diffs and transfer over in my Taco, but not the engine yet. Haven't made up my mind if I will.
  7. Dec 26, 2009 at 10:51 AM
    BSP4x4
    BSP4x4 [OP] Guest
    anyone know what the spec torque is for the plugs? or where to find that info?
  8. Dec 26, 2009 at 12:16 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
  9. Dec 26, 2009 at 9:46 PM
    BSP4x4
    BSP4x4 [OP] Guest
    thanks...if i don't have a torque wrench, will a few medium cranks be ok?
    also noticed a TON of sludge attached to the magnet in the tranny drain plug? is this normal? I'm assuming it was metal shavings?
    the truck is new (2009) (10K miles)...first time changing the fluid from stock to MT 90
    also, i filled untill it just kept draining out, took about 2 qrts...i should be okay right? Not sure if it was exactly 2.3 qrts? Maybe i'll run it for a few miles and re check?
    ALSO: for people who don't have lifts...what is the best way to do this? (even though i don't plan on doing it again anytime soon)...i first thought I could use a funnel to fill up the tranny, that didn't work because the fill plug is on the SIDE of the tranny. Then tried some tubing that ran from the fill hole up through the engine to a funnel, that worked okay, but the tubing was too thin and it took for ever, ended up using a pump type deal (took for ever too)...thinking about getting a funnel that can be used sideways (if they make them) or wider tubing? thougths?
  10. Dec 26, 2009 at 11:14 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    I would say it's pretty normal to have a bunch of fine shavings attached to the drain plug magnet, that's what it is for. This may be especially true for new transmissions because the initial break-in period will probably produce more shavings than a period of equal mileage after break-in.
  11. Dec 27, 2009 at 12:03 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    You can get a hand pump from the auto parts store that screws onto the gear oil bottle. It has a tube on it so you can put the tube in the filler hole and use your other hand to activate the pump. It's a must have if the gear oil you're using doesn't come in the type of bottles that have a cone tip. I think there's a picture of one in the "how to change your differential fluid" sticky
