Will I get a level 2.5" - 3" with this setup?
Discussion in 'Suspension' started by Strictlytoyz, Sep 15, 2015.
  1. Sep 15, 2015 at 5:35 AM
    Strictlytoyz
    Strictlytoyz [OP] Well-Known Member
    Charles
    Maui, HI / Tampa, FL
    07 Tacoma DCSB TRD OR 4x4
    So im looking to get atleast 2.5" - 3" of lift and have been leaning towards king. This truck is my DD but also will be doing a bit of rock crawling. Question is will i be able to obtain a level 2.5" - 3" with these products listed
    Front:
    2.5” Remote Reservoir w/comp adjusters
    PN: 25001-119-A
    Total chaos uniball UCA
    PN: 96504
    Rear:
    Performance Series 2.5” 1-2” Lift w/comp adjuster
    PN: 25001-121-A-E
    Stuck between
    2.75" Lift Dakar Leaf Pack
    PN: CS047R**
    And
    Deaver 1.5" Lift Leaf Pack
    PN: J-66*/***
    Thanks in advance. Let me know if im missing anything
    YotaDan likes this.
  2. Sep 15, 2015 at 9:56 AM
    Jon4x4
    Jon4x4 Well-Known Member
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    If you do the same lift up front and in the rear, the truck will look like factory, but 2-3" higher.
    2.5 up front, with 1.5 in the rear, it'' be around 1/4 - 1/2" higher in the rear.
    3" up front and 1" in the rear seems to be absolutely level in my experience
    YotaDan likes this.
  3. Sep 15, 2015 at 10:03 AM
    Strictlytoyz
    Charles
    Thanks for the feedback. So does that mean i need to find a different option for the rear? Any recommendations? Also is there any other parts that i need that im missing?
  4. Sep 15, 2015 at 10:06 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    You can remove 1 of the 2 overloads on the Dakars and they will retain the same ride characteristics but be about 1.5-1.75" of lift. Which is a good match for the front if you put some gear/light loads in the back once in a while or while wheeling.
    Jon4x4 likes this.
  5. Sep 15, 2015 at 10:10 AM
    Strictlytoyz
    Charles
    Thank you for the information. So would you recommend me pulling the trigger on this setup? Compared to the Fox ultimate suspension kit?
  6. Sep 15, 2015 at 10:12 AM
    Jon4x4
    Deltona, Fl
    1996 T4R
    3” kit 305’s
    3" in the front, and the deavers, they'll sag out a little bit over time, as long as you can deal with a little rake for the first few thousand miles.
    Dan is right as well, you can alwats pull some leafs
  7. Sep 15, 2015 at 10:16 AM
    Strictlytoyz
    Charles
    Okay thanks. I plan on eventually putting on a pelfreybilt rear bumber as well so that should help bring the rear down a little
  8. Sep 15, 2015 at 10:16 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    That would be a pretty awesome setup with the Kings. I think we have all that in stock at this time as well.
  9. Sep 15, 2015 at 10:21 AM
    Strictlytoyz
    Charles
    One more quick question. Would you reccomend i just go with the extended travel since ill be purchasing TC UCA's
  10. Sep 15, 2015 at 10:23 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I would. Only time you would cause any extra strain on the stock UCAs is if you are lifting tires off the ground.
  11. Sep 15, 2015 at 10:30 AM
    Strictlytoyz
    Charles
    Okay cool. Looks like i know what I'm gonna get. I just need to save up a little more. Any chance you offer military discount? Hahaha
  12. Sep 15, 2015 at 10:39 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Pricing is pretty tight, but I'm sure we can work something out. Just give us a call or shoot over an email when you are ready.
  13. Sep 15, 2015 at 10:48 AM
    Strictlytoyz
    Charles
    Will do, thanks for all the help and information. Appreciate it
  14. Sep 15, 2015 at 12:07 PM
    Dr. Jekyll
    Dr. Jekyll Well-Known Member
    Jimmy
    Honolulu, HI
    2015 Black DCSB Limited PreRunner
    The bumper weighs nearly the same as the factory with a hitch so don't expect that to bring the rear down.
  15. Sep 15, 2015 at 12:14 PM
    Strictlytoyz
    Charles
    Oh, i thought the stock bumper weighed around 50 pounds? The hc bumper with a swing out gate is 190 pounds? Correct me if im wrong. Oh by the way, i cant wait to move back home. Miss it so much
  16. Sep 15, 2015 at 12:40 PM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    Sorry I meant the regular rear plate bumper which is 85lbs. and the factory bumper with tow hitch is close to 80lbs.
  17. Sep 15, 2015 at 12:43 PM
    Strictlytoyz
    Charles
    No worries. I should've been more clear on what rear bumper i was gonna be putting on
  18. Sep 15, 2015 at 12:46 PM
    Dr. Jekyll
    Jimmy
    Honolulu, HI
    So yes you will drop that rear with 190 more pounds!
  19. Sep 15, 2015 at 12:55 PM
    Strictlytoyz
    Charles
    But say i do get the regular rear bumper. Without the swing out gate, deavers would work fine? Just incase i change my mind and dont wanna cut into my truck hahaha
  20. Sep 15, 2015 at 12:56 PM
    KingTaco81
    KingTaco81 The guy, behind the guy, behind the guy
    Jr
    Bell & El Monte, CA
    DCSB OR
    Bunch of stuff
    just fyi OP,the ride will be a bit firmer up front the higher you go
