Will I have UCA rubbing problems with this set up?
Discussion in 'Wheels & Tires' started by GATACOMA, Oct 28, 2013.
  1. Oct 28, 2013 at 6:03 PM
    GATACOMA
    GATACOMA [OP] Active Member
    Does it Matter
    4x4
    I have a 2011 taco and have recently added a Toytec 3" lift with the 1/4 top plate spacer and add a leaf. I want to run 285/70/17 either BFG AT's or Nitto Terra Grapplers.
    I really like the Pro Comp LA Paz wheels. The spec are 6 on 5.5 17x8.5 Offset 0 and Backspacing of 4.75
    Will I have a UCA rubbing problem with these and 285's or any rubbing problems at all?
  2. Oct 29, 2013 at 11:29 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    I know a 4.5" backspacing will provide enough clearance. Those ones should probably work too.
  3. Nov 4, 2013 at 5:53 PM
    Rwood
    Rwood Well-Known Member
    Raymond
    WNC
    15 TRD Off-road
    I have a 3" lift and a 4.5 backspace wheel and am running 295/70/17 Trail Grapplers with stock UCA's
