Will I need new UCA's ?
Discussion in 'Suspension' started by taterdigger, Feb 22, 2013.
  1. Feb 22, 2013 at 2:56 PM
    taterdigger
    taterdigger [OP] Active Member
    Andy
    Sarasota, Florida
    08 TRD PreRunner
    OME 885x's Bilstein 5100's Wheelers 1.5 AAL LR UCA's Pioneer H/U
    Ok, this is what I have purchased so far. Waiting for me to have time to install.
    4 BFG Rugged Terrains 265/70/17
    2 OME 885's
    4 Bilstein 5100's
    rear 1.5 AAL
    Drivers side 1/4 spacer
    How Much front lift will I get? I plan on leaving the 5100's set at 0. I have been getting mixed information on whether or not I will need replace my UCA's and I want purchase them now and install them at the same time, So I don't have to pay for my truck to be aligned twice.
  2. Feb 22, 2013 at 3:00 PM
    85yote09taco
    85yote09taco Well-Known Member
    Eric
    York, PA
    Tacoma TRD OR
    3'' OME lift, TRD CAI, Built Right UCAs, 285 Goodyear DURATRACS, black steelies, Fog light anytime, DTRL, Alternating turn signal, Diff breather relocated, Carrier bearing drop, Weathertechs, Bestop, Extended SS brake lines, CBI Sliders w/kickout, Cab mount chop, Total Chaos LCA skids, All Pro skids, Satoshi(HomerTaco), Bruteforcefab ''HC'' rear bumper, Bruteforce Hybrid front bumper
    You should end up with around 2'', that is if you keep the Bilstein shocks at 0. You can adjust the Bilsteins to get 3'', but you'll need UCA's if you do so. If you plan on going with a wider tire you might want to get the UCA's as well because the stock ones may rub.
  3. Feb 22, 2013 at 5:11 PM
    taterdigger
    Andy
    Sarasota, Florida
    08 TRD PreRunner
    So at 2" I should be able to get a good alignment without UCA's?
  4. Feb 22, 2013 at 5:22 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Its when you get to 2.5 or 3 is when you should worry. Even then people get away with running stock UCAs
  5. Feb 22, 2013 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    the 885's are going to put you at 2.5" to 3" lift. new UCA;s with added caster would be recomended.
  6. Feb 22, 2013 at 5:38 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I got 2 1/2" with 885's on my DCLB 4x4
  7. Feb 22, 2013 at 6:22 PM
    taterdigger
    Andy
    Sarasota, Florida
    08 TRD PreRunner
    Sounding like new UCA's to be on the safe side
  8. Feb 22, 2013 at 6:26 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    X2
  9. Feb 22, 2013 at 6:36 PM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    OZ, how is your alignment with factory UCA's?
  10. Feb 22, 2013 at 6:45 PM
    OZ-T
    Peter North
    British Columbia
    My alignment is great , I have LR UCA's
  11. Feb 22, 2013 at 6:53 PM
    taterdigger
    Andy
    Sarasota, Florida
    08 TRD PreRunner
    Thanks guys, Gonna order up some LR UCA's.
  12. Feb 22, 2013 at 6:59 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Headstrong offroad has the best price i have seen
  13. Feb 22, 2013 at 7:02 PM
    taterdigger
    Andy
    Sarasota, Florida
    08 TRD PreRunner
    Good to know, I will check them out.
  14. Mar 1, 2013 at 7:15 PM
    taterdigger
    Andy
    Sarasota, Florida
    08 TRD PreRunner
    OK, So I got my LR UCA's in today from Headstrong. I understand the instructions for the caster setting, but where do I set the ball joint for the camber? Do I set it in towards truck or all the way out? Just want to make sure its driveable to the alignment shop.
  15. Mar 1, 2013 at 7:25 PM
    OZ-T
    Peter North
    British Columbia
    I set mine about 3/4 of the way toward the tire but you can adjust that afterwards too
