Will I need new wheels too?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 15DCSBTSS, Jan 16, 2016.
  1. Jan 16, 2016 at 9:37 AM
    15DCSBTSS
    15DCSBTSS [OP] Well-Known Member
    2015 Tacoma DCSB SR5 4x4 TSS
    Smittybilt Tri-Fold Tonneau, Pop N Lock Tailgate Handle, OME887/5100/LR UCA's/HS 3 LEAF (on order)
    Hello all.
    I am getting ready to order the OME 887X/5100/LR UCA/AAL package from Headstrong. I've been told that factory wheels may rub on the UCA's and have spent the last few hours Googling to no avail.
    So can someone tell me if my wheels will rub? I have the OEM T-Force 17" black wheels that come on GST TSS trucks.
    If I'll need new wheels, I'll have to wait until budget allows to order everything. I was considering selling my wheels/tires to help pay for the new set if needed. What are those worth with approximately 5300 miles on them? Thanks in advance!
  2. Jan 16, 2016 at 10:00 AM
    cseaman
    cseaman Well-Known Member
    Atropia
    2019 RS3, 2019 SQ5
    just buy wheel spacers.
  3. Jan 16, 2016 at 10:11 AM
    15DCSBTSS
    I am sure headstrong has something that will work. Thanks.
  4. Jan 16, 2016 at 10:19 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you will be fine.
    My stock TRD OR wheels and 265/75R16's clear my SPC lightracing uca's no problem. Thats with 5100's at the 1.75in setting on stock coils
  5. Jan 16, 2016 at 10:39 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    It's not the wheels that rub, it's the tires. 285s will rub the UCA with stock Tacoma wheels...I'm not sure what wheels those are that you have, but if I were you I'd look up the specs and compare them to the trd sport or OR wheels. If you are going to run 285s you will need wheel spacers or aftermarket wheels with more backspacing, ideal is 4.5". If you don't plan to run 285s or bigger you should be fine.
  6. Jan 16, 2016 at 12:14 PM
    R2tacos
    R2tacos Supertaco
    Jon
    Raton, New Mexico
    09 TRD Off Road 9” lift
    Everything listed I’ve done myself to truly know my truck. It’s the only way things should be done so you know it’s right. Pro Comp 6" lift front and rear Total Chaos adjustable upper control arms Icon coil overs 3” front lift making the front a 9” lift total Pro Comp Pro Runner shocks rear Old man emu 7 leaf pack U-bolt flip kit EBC Drilled and slotted rotors with racing pads Injen tuned intake Road armor front bumper blinker mod aluminum mesh grill LED dome light LED under hood by pressure switch under body LED LED side markers LED grill lights LED dome light LED interior floor lights LED dash board radio/ gauges LED bed lights LED red rear blinkers Paint matched side steps 1200W Kicker amp 2-JL Audio 500W 12" subs behind back seat black and blue neoprene seat covers front and rear Black and blue steering wheel cover Weathertech floor mats front and rear Weathertech window vents 33x12.5" Goodyear Duratracs 18" Addict all black XD series rims w spare Flowmaster muffler dumps before tires Smoked Painted rear tail lights on outside Smoked inside front lights w clear reflectors HID 10,000K ballast/light kit Siren/mic loudspeaker Lots o green paint. Looking Inside through the grill, clevises, Calipers, drums, lift kit parts,driveline, pumpkin, lids and covers inside the engine compartment.
    I have the totally adjustable Total Chaos UCA's and I would buy them again and again. Especially if ever going to a 6" lift. No 4 position limitation and I can put my balls where they need to be. Ha Ha! Most def needed with my nine in the front. 18" wheels minimum and most shops don't want to mess with a truck that has spacers so I'd go with the 4.5 b/s
  7. Jan 16, 2016 at 12:42 PM
    15DCSBTSS
    I'm not planning on changing tire size. I'm pretty sure that they are 265's but I will look when I go outside later.
  8. Jan 16, 2016 at 1:55 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    You will be fine then.
  9. Jan 16, 2016 at 7:14 PM
    15DCSBTSS
    Finally checked them. 265/65/17. Yeah, they're BFG Rugged Terrain's but there's no reason to replace them now as they are basically brand new. When the time comes I'll get something better.
  10. Jan 21, 2016 at 4:10 PM
    15DCSBTSS
    I may have found a deal too good to pass up on wheels. This mod bug is a bitch! So, just to clarify... will a 16x8 wheel with -12 offset work? Of course it is 6 lug...
  11. Jan 21, 2016 at 4:12 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    what back spacing?
  12. Jan 21, 2016 at 4:13 PM
    15DCSBTSS
    Let me check... gotta make a phone call LOL
  13. Jan 21, 2016 at 4:16 PM
    15DCSBTSS
    He said 4.5"
  14. Jan 21, 2016 at 4:25 PM
    gottaToy
    JJ
    1985 Moped
    you need 4.5 backspacing and 0 offset at least. Double check as I am no wheel expert, but i believe the negative offset pushes wheel away from the mounting surface, much like adding a spacer
  15. Jan 21, 2016 at 4:25 PM
    Dilleytech
    Dilleytech Well-Known Member
    Jakob
    White salmon, Washington
    07 AC SR5 4x4
    Front ARB bumper, LR UCA's, OME 885/90021 struts, Ome shocks rear, general springs HD leaf pack.
    A little off subject but will 5100's be too short for the 887 ome? those will be like what 3.5" of front lift on what looks like a truck with no heavy winch bumper.
  16. Jan 21, 2016 at 4:28 PM
    gottaToy
    JJ
    1985 Moped
    Hopefully you confirmed the package and that everything will work together by speaking with a person at headstrong?
  17. Jan 21, 2016 at 4:28 PM
    15DCSBTSS
    No the Bilsteins are set at 0. All the lift comes from the coil.
  18. Jan 21, 2016 at 4:29 PM
    15DCSBTSS
    And yes I ordered one of their pre-assembled "kits."
    gottaToy likes this.
  19. Jan 21, 2016 at 4:31 PM
    15DCSBTSS
    And a heavy winch bumper is in my future plans anyhow. But yeah... If there is an issue I'm sure headstrong will stand behind their product.
  20. Jan 21, 2016 at 4:35 PM
    Dilleytech
    Jakob
    07 AC SR5 4x4
    Gotcha. Just seems strange to me they sell kits that don't match OME shocks with the OME coils. Saving a buck I guess.. Carry on.
