Will I rub?
Discussion in 'Wheels & Tires' started by hspunaugle, Sep 24, 2024.
  1. Sep 24, 2024 at 10:40 PM
    hspunaugle
    hspunaugle [OP] New Member
    Hunter
    I am going to do a build on a third gen (this build will take a long time).
    I am just having a hard time picking the offset for the rims 0 vs -12 WITH 35in tires. I was wondering if anyone has done this build. I have read people rub on the UCA with 0 offset.
    I am hopping to eliminate rubbing as much as possible if not entirely.
    Here is my build planned out if you have anything to add or recommendations I'm open to anything, I just don't want to do spacers.
    Pt1
    Nitro Gear Package 3rd Gen Tacoma $1,650
    ? Arb 8in FRONT diff air locker $1,100
    Arb air lockers REAR diff $1,100
    air compressor for arb air-lockers $338
    For wiring lights and switch panels look at the playlist: Hunter’s Tacoma build
    No Cut Base Switch Panel for 3 Short Switches (Tacoma Double Cab) – Guild Outfitters $149
    Pt2
    Bilstein coilovers w/rearshockupgrade $2118
    1” diff drop kit $40
    R1 break rotors and pads $230
    C4fabrication high clearance fender liners
    $549
    C4 fabrication Body Mount Relocation Kit $249
    Bfg ko2 35x 12.5 all terrain tires $1,500
    OR
    35x12.5WILDPEAK A/T4W | Falken Tires $1,600
    Method bronze 17x9 0 rims $1,000
  2. Sep 24, 2024 at 10:55 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
