Will I weaken my leaf springs if I drill holes in them ?
Discussion in 'Suspension' started by OZ-T, May 2, 2012.
  1. May 2, 2012 at 2:08 PM
    OZ-T
    OZ-T [OP] You chose ... poorly
    Peter North
    British Columbia
    As the thread title states , I would like to drill an approx 3/8" hole in my Dakar leaf springs near the front and back to install some OEM leaf isolators to combat my Dakar squeak once and for all , but I am worried that I may weaken them , any thoughts ?
    Holes would be here , same size as the existing holes , but in the two leafs you can see that lack holes and isolators
  2. May 2, 2012 at 2:17 PM
    canoeski
    canoeski Well-Known Member
    Bill
    Southcentral Wisc
    2012 Tacoma AccessCab
    Debadged. ARE Topper. Tailgate mods, including locking handle. BAMF LCA skids.
    I would think if the holes are close to the ends, there wouldn't be much to weaken.
    On my old truck, I took a heavy duty plastic laundry detergent jug (bright green is best;)) and cut up 2x4" pieces to use as isolators and smeared them liberally with anti-sieze for good measure. Held them in place with zip ties. Still working after 15 years when I sold the truck last week.
  3. May 2, 2012 at 2:19 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    NAAAAAAAAAAA Drill away.
    Better start a thread on how these springs suck so bad because they squeak :rofl:
  4. May 2, 2012 at 2:20 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    If you drill a hole in anything tempered you alter the temper with the heat created by the drill bit. It will also weaken the area of the spring you drill in,and may cause it to crack. Leafs distribute the weight they carry all the way across,so i would advise against it. Just use something like canoeski said. Far more simple and easy to do.
  5. May 2, 2012 at 2:20 PM
    OZ-T
    Peter North
    British Columbia
    Thanks for reponding
    I was worried because this is the military wrap end at the front of the leaf pack , also wondered why ARB didn't think it was a good idea to carry on with isolators there .
    I use strips of EPDM rubber between the leafs in this location , you can see the remnants of one in the pic , I was getting ready to replace it and that got me wondering about using isolators
  6. May 2, 2012 at 2:21 PM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    You should contact the manufactuer of the leaf springs for the answer to this question.
  7. May 2, 2012 at 2:21 PM
    OZ-T
    Peter North
    British Columbia
    Lol
    The springs are great , and they only squeak during the summer or when I get grit in there
  8. May 2, 2012 at 2:22 PM
    OZ-T
    Peter North
    British Columbia
    Good call
    I'll email ARB tonight
  9. May 2, 2012 at 2:23 PM
    OZ-T
    Peter North
    British Columbia
    That's what I was worried about .
    I use a similar set up as posted above
  10. May 2, 2012 at 2:23 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    I agree............
  11. May 2, 2012 at 2:24 PM
    OZ-T
    Peter North
    British Columbia
    Duly noted
    Duly noted
  12. May 2, 2012 at 2:24 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    If it was mine I would drill away.
    If it was near the axle I would not due to the stress it sees there.
  13. May 2, 2012 at 2:25 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    Manufacturer's? What manufacturer's? We dont need no stinking manufacturer's :D
  14. May 2, 2012 at 2:29 PM
    OZ-T
    Peter North
    British Columbia
    That's exactly my point though , I think it sees more stress on the outside of the leaf due to leverage than inboard near the axle location
  15. May 2, 2012 at 2:30 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    hehehehe sorry about that. Wrong mouse click..
  16. May 2, 2012 at 2:32 PM
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    I read somewhere that somebody was using some lawnmower side wall to keep thier springs from squeaking. They just glued them on. Said it worked great and they have been on there for a good while now and hasnt lost any. I will see if I can figure out who it was. That would be a lot better than drilling.
  17. May 2, 2012 at 2:34 PM
    OZ-T
    Peter North
    British Columbia
    I'm already using a variation of the DIY Squeaky Leaf fix
  18. May 2, 2012 at 2:35 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    I WOULDNT DRILL HOLES IN THE LEAFS......
    DRILL HOLES IN YOUR HEAD ITS EASIER
  19. May 2, 2012 at 2:36 PM
    OZ-T
    Peter North
    British Columbia
    Did somebody just fart in here ?
  20. May 2, 2012 at 2:40 PM
    Country101
    NW Arkansas
    It was 4WD in his spring refurbishing thread.
    And I might have a little bit of gas....... :D
