Will Intake Hinder My 08 Sport?
Discussion in 'Performance and Tuning' started by BullKnob, Aug 7, 2008.
  1. Aug 7, 2008 at 11:55 AM
    BullKnob
    BullKnob [OP] Well-Known Member
    Utah
    08 Sport
    30' M/T Toyo Tires, 3" Tuff Country lift, Kenwood iPod adapter,Kenwood 7" sliding DvD player.
    K so I was looking at the Stage 2 Cold Air Intake System with Pro-Dry S on afefilters.com. I started looking at my 08 Sport and the Intake runs into my wheel well thus being pretty far from the warm air already.Question is if I put in an after market intake that will bring the filter out of the wheel well will that do more harm than good? Would I get more results by just adding a larger filter to the intake I have. I will add pics so you guys see what i'm talking about.
    My buddy has a souped up dodge and I am just trying to blow his ass out of the water, so any suggestions on how I will get the most performance out of my Taco please let me know.
  2. Aug 7, 2008 at 11:58 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    You could start with a high flow replacement filter. If you wanted to do an intake, I like the URD.
  3. Aug 7, 2008 at 12:06 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    if its a hemi, you need a SC. An intake will help some
  4. Aug 7, 2008 at 12:47 PM
    BullKnob
    Utah
    08 Sport
    I was actually flirting with the idea of a SC what would that fun on installation do you think?
  5. Aug 7, 2008 at 12:50 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I would avoid the URD if you go Off Road at all or live an area that floods.
  6. Aug 7, 2008 at 12:50 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I would venture to say you would spend $4500 to get that installed.
  7. Aug 7, 2008 at 12:51 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    I agree about the offroad and it really depends on your def of flooding. 6" of water in the street counts as flooding to me, but I wouldn't be worried about 6" in the street with my URD.
  8. Aug 7, 2008 at 1:08 PM
    BullKnob
    Utah
    08 Sport
    Avoid off roading because of dirt getting in there? I live close to the mountains here in utah and I love to camp so I don't know if that would a good choice then. Is there another one that would work better?
  9. Aug 7, 2008 at 1:32 PM
    Khaos
    Khaos Big Member
    Bryant
    Dirt could be a problem, by my main concern with the URD unit is water/hydrolock. The location of the URD is not very good if your going to do any water crossings or if you go to fast through some water. But if you don't off road much it should be fine.
  10. Aug 7, 2008 at 1:34 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    it is an issue of water, not dirt.
  11. Aug 7, 2008 at 1:37 PM
    BullKnob
    Utah
    08 Sport
    I see So what if I just got the filter and left the intake in the wheel well? Would that work or would I just be better of getting a whole new intake with a housing like the afe system?
  12. Aug 13, 2008 at 8:28 PM
    jguinn2005
    jguinn2005 Active Member
    Harrisonburg, VA
    2008 SR5 TRD Off-Road Blacked Out
    I just put the URD TCAI on my taco, work amazing. I noticed an immediate mid to high range response in my throttle. However, I can tell you with experience that you're not going to beat a Hemi with it (yes, I tried it) but you should be able to beat a Duramax as long as its stock ... yes, I did that too, but I've also got the 6 speed so I was quick off the line. Anyhow, the URD is a good option in the way of an intake, and as for the offroading, as long as you don't cross any streams that would throw water into your grill you'll be fine the dust and such is what the filter is for.
    I'd look into the SC too if you're really wanting to beat that Hemi though ... if he's put aftermarket performance parts on it ... I might look into a 2009 Camaro SS or a Roushe Mustang, LOL.
  13. Aug 13, 2008 at 8:32 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd skip on an intake and just go with a high flow filter such as the afe pro dry s drop in filter. an intake gets most of its power from the upper rpms anyway, and if you are just doing normal driving, then its not really needed, because, since they cost so much, and a filter costs alot less, you'll save money that way, while also getting better mileage with just a filter. hope that made sense.:)
  14. Aug 13, 2008 at 8:41 PM
    Anthony
    Anthony San Antonio Detailer :)
    Houston - Spring/Tomball area
    06 prerunner access cab 2.7L M5
    Nfabs Afe Pro Dry UWS linex'd toolbox
    x 2.
  15. Aug 15, 2008 at 6:02 PM
    ahigginsdeca
    ahigginsdeca Higgins
    Alex
    Fort Collins, CO
    08 TRD shortbed
    3" Revtek Suspension Lift with a rear aal, 285/70/17 Pro Comp Xtreme M/T & Pro Comp Extreme Alloy 7189 wheels, magna flow exhaust, CB with dual antennas, AFE Cold Air Intake, CB Radio with dual antennas and a bull horn
    i have a magna flow exhaust with a dual conversion and I just installed a AFE cold air intake on it and am really impressed with it. I get a little bit more power off of the line and it sounds good at higher RPM's. Plus, it makes my exhaust system sound a little bit better and deeper. If you're going for a bit more power and a slight increase in sound and depth, than I definately recommend this one!
