Will it fit?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Oct 8, 2011.
  1. Oct 8, 2011 at 9:09 PM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Hampton Roads, VA
    2006 TRD-Sport Silver Streak Mica
    Bilstein 5100's with AAL in rear, 265/70/R17 BFG KO2 tires on 17x9 Fuel Maverick Machined rims with 4.5BS and -12mm Offset.
    a guy is selling a set of mickey thompson classic II rims, for 200 bucks. i wanna get them but i dont know if they will fit. they are 18x10s. the 10 in wide part is what worries me. can i fit em? even if i have to put some small wheel spacers?
  2. Oct 9, 2011 at 5:36 AM
    tacoman00
    Hampton Roads, VA
    somebody please!
  3. Oct 9, 2011 at 5:55 AM
    hard2kill
    hard2kill Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    whats the backspacing? offset?
  4. Oct 9, 2011 at 6:22 AM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    watch out with the wheelspacers. I just went through the same thing. I got a set of Eagle Alloys real cheap. They stuck out way too far with my Spidertrax. Without the Spidertrax, they scraped the caliper on the front. So I had to go with a 1/4" wheelspacer. The wheelspacers are not hubcentric so you'll get vibration. I cut up finish nails to center them on the hub temporarily while mounting the wheel and minimized the vibration. Also, check the flange thickness. My new ones are 1/2" thick which didn't leave enough stud for safety so I ended up having to replace all the wheel studs with longer ones. For the wheels, it was worth the effort especially being the deal I got, but it took a lot to make it work.
  5. Oct 9, 2011 at 6:28 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  6. Oct 9, 2011 at 3:39 PM
    s1nner
    s1nner Well-Known Member
    michael
    chesapeake,va
    06 trd offroad
    6" fabtech suspension lift, 3" body lift, 36x15.5 mtz on mt classic II wheels with red fake beadlock, shaved tailgate handle, custom paint, trd sport hood
    im running 16x12 classic 2's with a 1.5 inch spacer. they do fine as long as you have the right lug nuts. as long as you are ok with your tires sticking out i say go for it
  7. Oct 25, 2011 at 5:49 PM
    92879 Active Member
    SAM
    San Diego, CA
    2017 Tacoma DCSB 4WD off road
    im running 16x12 classic IIs also. with only a 1/4inch spacer and the lugs which are tapered. (they thread in deeper than normal)
