Will it rub?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aaron671, Apr 27, 2016.
  1. Apr 27, 2016 at 6:04 AM
    Aaron671
    Aaron671 [OP] Member
    2013 Tacoma 2wd
    3 inch lift, 1.5 wheel spacers
    Will 18inch rims with 285/60 rub on a 3 inch lift?
  2. Apr 27, 2016 at 6:17 AM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
  3. Apr 27, 2016 at 6:45 AM
    Pigpen
    Dan
    Northwest Montana
  4. Apr 27, 2016 at 4:23 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Maybe. The diameter is fine at 31.5 but the width is the potential problem. To keep 11.5s from rubbing on your knuckle and/or UCA the wheel backspacing will need to be different than stock. How different will determine if/how bad they rub on the pinch weld, cab mounts, etc.
