Will it rub?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mnmlod, May 4, 2018.
  1. May 4, 2018 at 3:56 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    Hi! I’ve searched the threads and found no definitive answer for my question. I’m interested in replacing the stock tires on my incoming 2018 TRD Pro with K02 265/75r16’s. They are only an inch taller. So, I’m assuming it’s only a 1/2 inch more reach towards the fenders and wheel wells. It looks like the new tires are a 1/2 inch narrower too. I want to keep the stock TRD Pro suspension. So, has anybody run this with no rubbing, and no trimming? Sorry in advance if this has been answered somewhere else. I really did read but only found guys saying they did it but with a lift or leveling kit or a different tire.
    Irvin92 likes this.
  2. May 4, 2018 at 3:59 PM
    Irvin92
    Irvin92 Well-Known Member
    Irvin
    Santa Fe Springs, CA
    2018 Toyota Tacoma trd-OR SB 4wd
    Yes they will absolutely rub! Jk 265/75/16 is the biggest size you can run without rubbing or any other issues
    gabbo2112 and Mnmlod[QUOTED][OP] like this.
  3. May 4, 2018 at 4:01 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    Ok. You are making me nervous. Lol
    gabbo2112 likes this.
  4. May 4, 2018 at 4:06 PM
    Irvin92
    Irvin
    You will be okay to run that size, If your getting a trd pro you will be more than fine...they come 1”inch higher than off-road models and OR model can run 265/75/16 without any issue with stock suspension
    Hope that helps, didn’t mean to confuse you lol
  5. May 4, 2018 at 4:07 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    No, you’re good. Thanks!
  6. May 4, 2018 at 4:11 PM
    SeeWhatHadHappenedWas...
    SeeWhatHadHappenedWas... Well-Known Member
    Jeremiah
    Oregon
    2017 OR DCSB MT Quicksand
    The only thing it could rub would be the oem mud flaps if you have them. Some people need to bend, move or take them off. I would suggest rock blocks mudflaps I took my oem off for them. They are bendable so they won’t get torn off if they rub the ground. The look is way better I think too.
    gabbo2112 and Mnmlod[OP] like this.
  7. May 4, 2018 at 4:20 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    Thanks! I think mine is flapless. Is that a word even.
  8. May 4, 2018 at 4:40 PM
    Jeremiah
    Oregon
    It’s a word now. At least you don’t have to put in the work to take them off to instal your nice flaps.
    Mnmlod[OP] likes this.
  9. May 4, 2018 at 4:44 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    True. That’s a whole other thread though. “ Flap or Flapless “.
  10. May 4, 2018 at 5:02 PM
    Rob Daman
    Rob Daman The Taco Formerly Known as Hard Shell Taco
    Rob
    So Cal
    17 OR 6MT
    a lot
    he's right. wheels and tires you'll be fine as is.
  11. May 4, 2018 at 5:04 PM
    Fyreguy11
    Fyreguy11 Well-Known Member
    North Texas
    2018 DCLB 4x4 TRD Off Road
    You're good on the 265/75/16 tires. They will fill out the wheel wells a little and not rub.
  12. May 4, 2018 at 5:06 PM
    DLRIII
    DLRIII Well-Known Member
    David
    Baton Rouge
    2018 Quicksand SR5 DCSB V6
    You're definitely good man, I have 265/75/r16s on my SR5 and they have no run except I did have to remove the front mud flaps. The trd pro sits about an inch higher on the front end than the other trim levels, so you should clear them even better than we do. The 265s fill out the wheel wells nicely
  13. May 4, 2018 at 5:12 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    Thanks guys. I’m getting them.
    Irvin92 likes this.
  14. May 4, 2018 at 5:22 PM
    Irvin92
    Irvin
    Don’t forget to post pics when you do :thumbsup:
    Mnmlod[QUOTED][OP] likes this.
  15. May 4, 2018 at 5:26 PM
    Mnmlod
    Mnmlod [OP] Newb
    Yosemite
    2018 TRD Pro
    I will
  16. May 4, 2018 at 5:52 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Welcome back to another segment of WILL. IT. RUB.
    Tacoislyfe92, tcjacado and DrSouthpaw like this.
  17. May 4, 2018 at 6:17 PM
    NOLAMedic
    NOLAMedic Well-Known Member
    2018 Quicksand DCLB TRD Off Road
    No but it won't fill out the wheel well like a 255/85/16.....which also doesn't rub
    THATCH11B likes this.
  18. May 4, 2018 at 6:20 PM
    Jeremiah
    Oregon
    Do you need the height of a pro to run 255/80/17? Or can a off road run them too?
  19. May 4, 2018 at 6:28 PM
    Irvin92
    Irvin
    An off-road can run them as well, that size tire performs good off-road but they are too skinny for my taste lol
  20. May 4, 2018 at 6:32 PM
    Jeremiah
    Oregon
    Cool, thanks for the info. I just checked the at3 size list and they don’t even make that size so I don’t think I’ll go that size. If I go with the st maxx though I may get that size.
    Irvin92[QUOTED] likes this.
