Will it Work
Discussion in '1st Gen. Tacomas (1995-2004)' started by bklf7, Mar 30, 2009.
  1. Mar 30, 2009 at 4:34 AM
    bklf7
    bklf7 [OP] New Member
    Orford, NH
    01 Tacoma
    I am buying an 01 tacoma extra cab with a blown 4 cylinder motor for 700 bucks. It only has 111 thousand miles on it. If I find an older 2.7 that has a distributor can I make that motor work on a non distributor motor?
  2. Mar 30, 2009 at 9:17 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    great deal
    idk if it wold work tho
  3. Mar 30, 2009 at 9:27 AM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    Diesel!!!
  4. Mar 30, 2009 at 9:36 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    I dont really understand your question. Do you just need to replace the distributor or talking about a engine swap. I would take it to a machine shop so they can rebuild the motor it may be cheaper than a engine shop iam not sure. A "blown" engine can mean anything like running it without oil letting it overheat. Spark plugs need to be replaced, etc.
  5. Mar 30, 2009 at 10:53 AM
    bklf7
    Orford, NH
    01 Tacoma
    Ok to clarify. One of the connecting rods came out the side so the block is junk. If I get an earlier 2.7 that has a distributor can I block off where the diz goes into the motor and make that motor work with coil packs which is what I understand toyota changed to later on. And this is a gas motor.
  6. Mar 30, 2009 at 4:18 PM
    borderbrat
    Jeremy
    Victoria BC, Canada
    And I'm saying go diesel if you're replacing the motor go diesel.
  7. Mar 31, 2009 at 4:33 AM
    bklf7
    Orford, NH
    01 Tacoma
    I actually got this truck to replace the motor and then sell it so the deisel motor is out of the question.
  8. Mar 31, 2009 at 5:39 AM
    cole47
    cole47 Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    where is chris????? lol
  9. Mar 31, 2009 at 7:48 AM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    the distributor was only used in like 95.5-96 trucks so the coil pack engines are actually alot easier to find... but as for you question you would probably HAVE to use the coil pack head fo it to work
  10. Mar 31, 2009 at 1:33 PM
    bklf7
    Orford, NH
    01 Tacoma
    Ok good to know. Thanks
