will it work?
Discussion in '1st Gen. Tacomas (1995-2004)' started by blkcoma32, Aug 7, 2009.
  1. Aug 7, 2009 at 10:00 AM
    blkcoma32
    blkcoma32 [OP] Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    I was wondering if anyone knows if a 01-04 gauge cluster will fit/work in a 98?
  2. Aug 7, 2009 at 7:00 PM
    blkcoma32
    Illinois
    Nobody?
  3. Aug 7, 2009 at 8:19 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    how about a 96??
    ive always wanted a stock tach...
  4. Aug 8, 2009 at 8:38 AM
    da0023
    da0023 The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    i am pretty sure it will fit, i have read previous threads on it, i just can't seem to find them right now. just be sure to remove the odometer wheel from your cluster and put it in the new one so that your mileage will be correct. the rest should be just plug and play. i have been thinking about doing this as well, my 99 doesn't have a tach, i don't need it, but i think the instrument cluster would look better if it had one. let me know how it turns out. :)
  5. Aug 8, 2009 at 10:33 AM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
    yes.....
  6. Aug 8, 2009 at 11:03 AM
    STLharry
    Harry
    VT
    yes it will work?
  7. Aug 8, 2009 at 11:03 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Yes.
  8. Aug 8, 2009 at 11:24 AM
    STLharry
    Harry
    VT
    Sweet. I just called yota yard in colorado and they said it was 100 for an instrument cluster. Is it just a replace and plug in type thing?
    I mean, I dont have a tach in my taco right now, so is there still a place to plug the one off the cluster in?
  9. Aug 11, 2009 at 6:50 PM
    blkcoma32
    Illinois
    you will probably have to run a wire to the motor, im not sure if the cluster wiring from a non-tach taco has a wire for it even though it doesnt have a actual tach.
    Thanks guys for all the input, if any finds any threads on this let me know, THANKS
