Will lift and wider tires change mpg?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jeremy15, Dec 29, 2017.
  1. Dec 29, 2017 at 3:37 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Filled up christmas day and calculated 11.6 myself.
    Shmellmopwho[QUOTED] likes this.
  2. Dec 29, 2017 at 3:47 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I have a modest lift (2"), and avg 20-21 mpg in summer conditions.
    I also run P rated 265/70/17's, with stock Tundra wheels that weigh 27 lbs (weigh roughly 1 lb more than the factory wheels).
  3. Dec 29, 2017 at 3:55 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    PIG!! Oink oink!!
  4. Dec 29, 2017 at 4:26 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    At the moment, Torque is telling me I'm averaging 12mpgs. Probably the lowest in the ten years I've owned the truck. Don't know if it's the tires, "winter gas", or just age of the truck. I used to meet or exceed the EPA estimate on 305/60r18s. Now I can't come close with the same tire in 285's.
  5. Dec 30, 2017 at 11:13 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Just because the rims are wider, doesn't mean the tires are wider. 245 is actually very narrow. 265 is stock.
    Heavier wheels = lower MPGs and heavier tires = lower MPGs.
    A lift increases wind resistance which lowers MPGs as well.
  6. Dec 30, 2017 at 1:11 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Lots of variables, but you're not doing anything too radical so I'd not expect a huge difference, maybe 1-2 mpg. But generally wider tires with more aggressive tread creates more rolling resistance and hurts fuel mileage. Skinny tires with less aggressive tread does better. Lifting the truck will hurt aerodynamics. Larger diameter tires change the axle ratios and really mess with engine performance if tires are too large unless you regear.
    Basically the further you go from stock, the worse fuel mileage and engine performance you'll get
  7. Dec 30, 2017 at 3:12 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    :rofl: well stated....
  8. Jan 16, 2018 at 9:20 AM
    Jeremy15
    Jeremy15 [OP] Well-Known Member
    Jeremy
    Boone NC
    '12 Tacoma Prerunner
    How will my speedometer be affected if I go up to 265/75/16 from 245/60/16?
  9. Jan 16, 2018 at 9:25 AM
    jimmydean
    jimmydean Well-Known Member
    Camarillo, CA
    16' DCSB TRD SPORT 6M
    Limited Grill/Wheels, 265/65/18 Nitto RG
    245/60/16? Thats not a standard tire size for a tacoma. Are you sure you don't mean 245/70/16? This site will help you figure out the changes
  10. Jan 16, 2018 at 9:27 AM
    Jeremy15
    Jeremy
    Boone NC
    Yes 245/70/16 is what I meant.
  11. Jan 16, 2018 at 9:29 AM
    jimmydean
    Camarillo, CA
    Your indicated speed will register a couple MPH slower than your actual speed. You'll probably lose a couple MPG.
  12. Jan 16, 2018 at 10:16 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    I recently took a road trip and was blown away i could watch my gas gauge plummet as I drove on the highwya @ 80mph...... I recently switched from 265/70-17 BFG AT KO (load range C) to 265/70-17 Cooper Discoverer STT Pros (load range E) and after seeing how much they killed my mileage I have already started shopping to go back to the BFGs.... anyone in the midwest interested in the stt pros haha?
    DavesTaco68 likes this.
  13. Jan 16, 2018 at 10:27 AM
    redrock95
    redrock95 Well-Known Member
    White 2012 Tacoma TRD Offroad, Manual 6-spd
    I havent gotten 21 once in the entireity of the history of my 6spd 4.0.... tell me your wise ways. I live in utah as well and primarily drive highway.
  14. Jan 16, 2018 at 10:37 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Its all about those funs per gallon anyways. mpg is irrelevant
  15. Jan 16, 2018 at 10:40 AM
    #35
    Jeremy15
    Jeremy
    Boone NC
    Okay thanks for the info
  16. Jan 16, 2018 at 10:43 AM
    #36
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I have a 2011 TRD offroad, after adding 285/75/16 tires, I'm 1mph off at 65mph.
  17. Jan 16, 2018 at 11:04 AM
    #37
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I get about 19 MPG with my 35in tires and a 4 in lift on my 95 F350 4x4 CCLB 7.3 diesel
    14 MPG when towing 11.5 k
  18. Jan 16, 2018 at 11:10 AM
    #38
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    yes. even going to an aggressive mud terrain will change MPG for the worse.
  19. Jan 16, 2018 at 11:39 AM
    #39
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    245/70-16 is NOT a standard size either. 245/75-16 is.
  20. Jan 16, 2018 at 11:48 AM
    #40
    Jeremy15
    Jeremy
    Boone NC
    Okay
