Will lifting void my warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bobbybreach, Mar 16, 2016.
  1. Mar 16, 2016 at 4:47 AM
    bobbybreach
    bobbybreach [OP] Well-Known Member
    bobby
    westchester NY
    09 TRD
    I'm looking to do a 3" lift and probably change the exhaust. Will that void my warranty? The dealership was not sure if it would. I just have the factory warranty.
  2. Mar 16, 2016 at 6:12 AM
    Ultrarunner7
    Ultrarunner7 Well-Known Member
    Northern Virginia
    2016 White Toyota Tacoma Sport 4 door
    Bilstein 5160s in rear with Toltec Progressive 3 leaf spring, Bilstein 6112s in the front
    Google Magnuson Moss Warranty Act.
  3. Mar 16, 2016 at 6:36 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    You're dealer doesn't know???
    No, it won't void your warranty if the lift is not the cause of the failure.
  4. Mar 16, 2016 at 9:29 AM
    Mnewman03
    Mnewman03 Well-Known Member
    2016 MGM DCSB TRD OR
    Depends on the dealer. It could end up being a fight for you.
  5. Mar 16, 2016 at 9:47 AM
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    Yes (OP), there is some truth to this statement regardless of the MM Act. The dealer processes the warranty claims, and they can deny your claim based on your additions. This does not mean that your warranty was voided, it just means that the dealer chose, at their discretion, to not honor it for the particular issue based on their assumptions. You would then have to try other options like go to another dealer, possibly lawyer up, etc. (i.e. fight) to get them to "prove" that your mod caused the particular issue at hand. Otherwise they have to fix it under warranty.
    But be clear, your overall warranty is unaffected regardless. Only something that can be proven to be caused by a particular modification is possibly voided. Lots of dealers put on lifts before even selling the truck with full warranty. Lots of companies warranty their aftermarket work, so you typically have everything covered.
  6. Mar 16, 2016 at 9:50 AM
    bsacamano
    bsacamano Well-Known Member
    2016 Tacoma Sport DCLB V6 4x4
    And, just to be clear, no matter what happens, the dealer will claim that the modifications "could" have resulted in the failure.
  7. Mar 16, 2016 at 9:50 AM
    Andres
    Andres Well-Known Member Vendor
    Andres
    Hawthorne, CA
    2013 Toyota Tacoma TRD off-road
    It depends on the dealer.
    Get the general manager if someone at your dealer says he doesn't know.
  8. Mar 16, 2016 at 10:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    To pile on, you lose warranty on the replaced parts for sure. But suspect (hope) you already figured that out.
    Driveline issues that might occur related to the lift would quite likely be denied as well.
    Arailt likes this.
  9. Mar 16, 2016 at 12:26 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    ...ummm they have to "prove" not guess.
