Will Long Travel work on my Truck?
Discussion in 'Long Travel Suspension' started by BCollett, Jan 2, 2014.
  1. Jan 2, 2014 at 6:21 PM
    BCollett
    BCollett [OP] Well-Known Member
    Brandon
    Hesperia Ca
    01 Limited Dbl Cab 4x4
    Pro Comp Lift.
    I've been trying to figure out what upgrades i could do for my front suspension. I would like to get a Long/Mid travel kit but there is one snag... I have a 01 4 door Tacoma. I installed a 4" lift kit years ago so i could squeeze some 33"s under it. There is one issue. The kit replaced the original lower cross member where the lower control arms mount with a new cross member that drops everything down by 4".... the Original cross member was cut out to allow for the differential to be lowered along with the new cross member. I still have stock steering knuckles installed but they require a spacer to be installed on the tops of them to extend them, and the shocks also have spacers on top of them to make up the difference.
    So I guess the question is this.... Does anyone think it would be possible to install a Total Chaos or Camburg kit on the front end?
    If this isn't an option i suppose i could hack everything off and SAS it.....
  2. Jan 2, 2014 at 7:59 PM
    Rylee
    Rylee Well-Known Member
    Rylee
    Mission Viejo
    07 dcsb long travel
    Engage front kit, 35" hankook mt, Glassworks, Deavers.
    someone has done it, the geometry however is no longer the same.
  3. Jan 2, 2014 at 10:59 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
    You can always chop the crossmember out of another truck and weld it in then pull the lift out and install your mid travel or long travel.
  4. Jan 3, 2014 at 8:22 AM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    So you have a Diff Drop, want Long Travel, but might go SAS if all else fails. Do you have any plans or goals as that could help in deciding your lift
  5. Jan 3, 2014 at 8:25 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    anything is possible with a grinder and a welder.
  6. Jan 3, 2014 at 8:38 AM
    wheelerkr2
    wheelerkr2 Well-Known Member
    Kevin
    Yorktown/School in VT
    08 TRD Rugged Trail
    SOS Concepts Sliders,Debadge,BHLM,Colormatched Grill,Bilstein 5100's,OME 885 coils, Toytec 2" AAL General Grabber at2 285/75r16
    and money :D
  7. Jan 3, 2014 at 4:26 PM
    BCollett
    Brandon
    Hesperia Ca
    Pro Comp Lift.
    Well the truck will primarily be for camping trips and long offroad trails (like the mojave trail..) I'm not going to be doing any serious crawling or anything that would benefit from a SAS... (it might be the easier option though since everything gets chopped off the front end ....) This is why i'm thinking some kind of long/mid travel would be the better choice. I think keeping the IFS would keep the ride smoother over all.
  8. Jan 3, 2014 at 6:34 PM
    thekernel114
    Chilliwack, B.C.
    07 tacoma 4x4
    it would be easier to pull the lift you have now out and weld the section of the crossmember you cut back in. then install what ever mid travel or longtravel you want after that. sas is pretty involved and expensive compared to the above.
  9. Jan 3, 2014 at 7:21 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    Plus a big hammer, busted knuckles, and liberal application of the words "fuck" and "shit".
    Silver Devil Yota likes this.
