Will low clutch fluid throw a check engine light???
Discussion in 'Technical Chat' started by 01kingtaco, Oct 4, 2012.
  1. Oct 4, 2012 at 11:14 PM
    01kingtaco
    01kingtaco [OP] Well-Known Member
    Kodiak
    Maui hawaii
    01 taco slightly modded
    Bigger tires, sound system, deck plate mod, fog light mod, straight pipe exhaust, blue led floor lights, ultragauge, 3 inch lift
    My check engine light came on today while driving. All fluids up to par running just fine not shuddering or anything just the light poped on. Only thing I saw that was a lil low right at minimum so I added some and took the negative battery terminal off for a minute nd put it back on started it up no light drove it 10 miles with nothing don't get it! Any help?
  2. Oct 5, 2012 at 6:02 AM
    shemp
    shemp Well-Known Member
    Its a good idea to read the code when you get a check engine light. It will tell you which sensor is triggering the light.
  3. Oct 6, 2012 at 12:30 PM
    01kingtaco
    Kodiak
    Maui hawaii
    Yea it's not clutch fluid cuz I topped it off unplugged the battery and pluged it back in and the light went off drove about 26 miles ns it poped back on again. So idk what it could be
  4. Oct 6, 2012 at 12:37 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Why is your clutch fluid low?
  5. Oct 7, 2012 at 11:56 AM
    01kingtaco
    Kodiak
    Maui hawaii
    Im not sure just saw that it was low
  6. Oct 7, 2012 at 12:00 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The only time 1gen trucks are low is because there is a leak. 2gen shares its reservoir with the brakes. 1gen has a separate reservoir.
  7. Oct 7, 2012 at 12:03 PM
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    That explains why I could never find the resi for the clutch on my second gen.... and no low clutch will not throw a check engine code.
  8. Oct 7, 2012 at 12:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    CEL comes from the emission/fuel system.
    Common culprit if the engine seems to be running normally is the gas cap is not sealing properly... either because it's gone bad, or it's not fully tightened down. That's a cheap and easy fix, but without knowing the P0xxx code, we can't help you any more than that.
  9. Oct 8, 2012 at 12:15 PM
    01kingtaco
    Kodiak
    Maui hawaii
    It was a bank 1 catliytic insafceint flow code
