Will lug nuts from 16" steel wheels work on 17" FJ Alloys?
Discussion in 'Wheels & Tires' started by xxaarraa, Jun 9, 2011.
  1. Jun 9, 2011 at 8:25 AM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    I have an 09 4x4 SR5 with 16" steelies. I am thinking about upgrading to 17" FJ alloys - nothing flashy, just the straight up factory alloys from an FJ.
    Can I reuse my lugs or would I need new ones? If I need a full set of lugs, how much are they and do I get them from Toyota or any car parts store?
    Please help, thanks in advance.
  2. Jun 9, 2011 at 10:00 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    No they will not. The FJ style wheels require a different type of the lug, the kind with the washer on the end. The lugs on the steel wheels not only won't seat right, they carve and dig into the holes on the wheels.
  3. Jun 9, 2011 at 1:58 PM
    xxaarraa
    OK, that's what I feared. Thanks for clarifying.
    How much for a full set of lugs do you know?
  4. Jun 9, 2011 at 2:02 PM
    stunt man hans
    stunt man hans DISPLACED VIKING LIVING IN GEORGIA
    Hans
    LIVE FREE OR DIE
    2015 AEV RAM 3500
    FULL AEV PROSPECTOR KIT++
    call toyota.
  5. Jun 9, 2011 at 5:12 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Are the 16" steeples conical seat? Good to know. I thought all of the stock wheels except the gulf states ones were shank and washer,
  6. Jun 10, 2011 at 5:53 PM
    Yamaha Dave
    Yes the steel wheels use the conical sets because they are steel and they can support the load better than an aluminum wheel which is a softer metal and needs the shank and washer to distribute the load. If you used the conical lug nuts as mentioned they either won't sit correctly which is extremely dangerous or they will dig into the lug holes on the wheels and eventually ruin them.
  7. Jun 10, 2011 at 6:51 PM
    KPT
    09 Prerunner
    Hmmm how come almost all aftermarket aluminum rims use conical seat lugs if it's a materials properties issue?
  8. Jun 10, 2011 at 7:03 PM
    luk3
    luk3 I <3 the mall
    luke
    Isle of Palms, SC
    stanky taco
    Camburg spindles, All Pro leaf pack
    You cant use steel lugs for alloy wheels... I had to order stock alloy lugs from he steelership because I didnt know:(
