Will my 2018 OR fit in a parking garage with 6' 3" max height clearance?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JacksonTaco, Dec 25, 2021.
  1. Dec 25, 2021 at 2:30 PM
    JacksonTaco
    JacksonTaco [OP] Member
    2018 TRD OR DCSB
    Hi all,
    I checked the spec sheet for my 2018 OR, and its height is listed at 70.6". Everything is factory stock.
    There is an underground parking garage I want to use with a max height restriction of 6' 3" ( = 75" total).
    Will I be ok to park in this garage? I am not sure if this is leaving enough breathing room for tolerances in the truck and/or garage, nor am I sure if the 70.6" listed height on my truck includes the antenna or not.
    Don't want to bang up my roof. Thank you.
  2. Dec 25, 2021 at 2:40 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Definitely, maybe.
  3. Dec 25, 2021 at 2:41 PM
    Kyebasse
    Kyebasse Jd
    K
    21 Tacoma TRD Off-road
    As long as it’s on a factory height, it will fit. I have a 21 OR. I had the same concern when I went to this underground garage (6’3). I thought i was going to get stuck. I was looking up while crawling slowly. Even if you know for sure it fits, you will still look up and move slowly. It really feels you are cramped up while driving inside a short garage.
    Iwilltaco likes this.
  4. Dec 25, 2021 at 3:01 PM
    Mallrat60
    Mallrat60 Not all of us in CA are libs.
    Nor-Cal, Sacramento area
    2015 Dbl cab L/B 4X4
    ADS 2.5 #700 springs, RCI metal fab full skids, JBS UCA, OME rear leaves, Fab Fours front, and rear bumpers, BAMF Rock Sliders and other stuff
    No way I would fit. I bearly make the 7'2" carwash
  5. Dec 25, 2021 at 3:06 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Full take of gas, air down to 18 psi. Punch the gas and slam on the brakes, when you go in and aat all of the low hanging spots. You should be good.
  6. Dec 25, 2021 at 3:09 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    If stock, it will fit. My 2007 w/ a 3” lift and 1” bigger tires, the antenna hit at my work’s parking structure. I don’t mind b/c it’s a flexible antenna. But the newer shark fin antenna, it’s bad.
    Your best bet is, measure your truck and compare. There’s a low profile shark fin replacement you can buy. Or, cut the fin short and fill it with epoxy. There’s a few people done that already here on TW.
    Williston likes this.
  7. Dec 25, 2021 at 3:14 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    My 2018 OR fits in my 6’2” underground, shark fin and all. Stock height. Although, the first time I took it in was a bit dicey, even though I had measured a couple times.
  8. Dec 25, 2021 at 3:26 PM
    Clearwater Bill
    Billy
    Largo Florida
    A tape measure would be the tool to break out............
    Montana_Actual, DanoTay, 5465 and 7 others like this.
  9. Dec 25, 2021 at 3:27 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    Here's a novel thought: Measure it.
    Tape measure + a 4' level sitting on the fin.
  10. Dec 25, 2021 at 3:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Take one measurement from the ground to the square tube on the headboard. Get in the bed and take a second measurement from the square tube to the top of the sharkfin. Add the two measurements together. Ideally do it with an almost empty fuel tank and full pressure in the tires, to get the worst-case scenario.
    Repeat after any mods like a suspension lift or bigger tires.
    My truck with 3" lift and 35" tires measured out to 77.8", so stock should be close to 72.8". That means the owner's manual spec doesn't include the sharkfin.
  11. Dec 25, 2021 at 3:44 PM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I just measured my 2021 OR a few min ago, stock, and it’s shy of 72” to the top of the antenna. Measure your parking structure to confirm the clearance height. Most of the time they give a lower measurement reading on purpose.
    DanoTay likes this.
  12. Dec 25, 2021 at 3:49 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer).
    Ditto on the above: "It's bad...." is an understatement. (IMO) That Shark Fin antenna is a very costly item/part to replace; never mind the labor! The one on my 2014 leaked the first downpour after I drove it home from the dealer last June. (2 days) The dealer was excellent about replacing it, but it took two tries to get it completely water-tight. There wasn't a mark on it, (I checked it) but it wasn't sitting perfectly flush on the roof either. I suspect an automated car-wash after it was traded in. There was no evidence of a prior or long term leak above the headliner or on the bulkhead or carpeting below the rear seats; I saw it when they had the entire interior out, including the seats, carpets and headliner to dry it completely out. I'm glad it happened quick and I was out there to see it leaking in real time. It's a crazy-ridiculous priced part. (see below)
    So re: low ceiling: "Know before you go." Just because it says: "6.3" on the sign, doesn't mean the contractor got it right throughout the entire structure, or the guy who certified the height didn't have a bad day, or that structure hasn't settled in spots or survived an earthquake unscathed. If you hear a scraping noise along the roof above your head: It's going to ruin your day! YMMV.
    2012-2015 Toyota Tacoma - GPS Antenna - Toyota 86860-04010 $667.41 (list)
    3JOH22A and DNguyen1033[QUOTED] like this.
  13. Dec 26, 2021 at 7:12 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I’m 6’3” tall and I’ve never hit my head walking in a parking garage. I can’t imagine one with that low of clearance.
    Tocamo likes this.
  14. Dec 26, 2021 at 7:35 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Design / fab together a Truckers Storie pole/ stick with square tubing ( truckers use this type of pole to measure overall height of a load ) . Fab it together in a L shape with the 90° bend at 6'3" max height . Then place the storie stick against the truck with the horizontal piece over the tallest part of your truck
    This stick will give you an accurate overall height of your truck for the low parking garages overall height
  15. Dec 26, 2021 at 8:07 AM
    philth
    philth .
    LOL ain’t nobody got time for measuring tapes or making some sort of measuring contraptions. Just haul ass into the underground parking and hope for the best.
  16. Dec 26, 2021 at 8:20 AM
    remote
    remote Well-Known Member
    Minnesota
    2021 DCSB Sport Cement
    pay attention to ramps going up and down in the garage. They will change approach and departure angles and could easily cause interference.
    MTaco2022 likes this.
  17. Dec 26, 2021 at 8:21 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    If you go fast enough......you'll only hit once. :eek:
    Typically, parking structures have a clearance bar at the entrance. If you don't hit the clearance bar, then your good.
  18. Dec 26, 2021 at 8:25 AM
    YellowSnow
    YellowSnow Chasing Pink Taco
    San Diego
    19 TRDOR
    KING/YOKOHAMA/RLD/RRW/RCI/BAJA/ROOFNEST
    Start dating some fat chicks and toss her friends in the bed.
    philth, vivid02 and DNguyen1033 like this.
  19. Dec 26, 2021 at 8:49 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Are there low hanging pipes attached to the ceiling of the garage? I had a clear passage through a parking garage once but then backed up and found out there were even lower pipes than the stated clearance on the sides of the ceiling, bent one of the bike trailer wheels that was up on my roof rack.
    To be sure, you really need to use a spotter. Forget depending on measurements and our opinions when you are there.
    CherylJane likes this.
  20. Dec 26, 2021 at 12:00 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    You have a choice between the opinions of random people on the internet or a tape measure. Choose wisely.
