Will my Taco sit level?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ben96, Jun 23, 2025.
  1. Jun 23, 2025 at 10:35 PM
    Ben96
    Ben96 [OP] Well-Known Member
    2014 Tacoma Sr5
    2.5in billstein 5100’s, OME 887’s, 1in rear block, Morimito LED’s, Level 8 MK6’s, Falken Rubitechs 265/75r17
    For context, I have a 2014 v6 Double cab Tacoma with 5100s on all 4 corners, stock coils on top clip, with 1 inch blocks. Rides like crap, lol.
    I’m planning to swap the coils for OME 887s, put the clips at the bottom, and get UCA’s. I just want to make sure it’ll sit level and not nose high. The plan is to eventually get new leaf packs for 1.5-2 inches in the rear for a little bit of rake, but I’d like to save that for later if possible, or go AAL.
    Thanks!
  2. Jun 24, 2025 at 12:29 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    You are probably around 1.75" in the front now. The 887's on the bottom clip should give you close to the same lift. So likely no different from what it looks like now.
    Are you replacing the coils and UCA's in hopes that it rides better?
  3. Jun 24, 2025 at 12:56 PM
    Ben96
    2014 Tacoma Sr5
    Yeah, the ride is one reason. And for a better alignment, which is the main reason.
  4. Jun 25, 2025 at 7:29 AM
    Saskabush
    Adam
    2013 TRD Sport
    Changing only the coils won't do much for ride quality unfortunately. On these trucks the ride is mostly dictated by the rear end. 2 things make a huge difference in that regard, better leafs and replacing the factory shackle hangers (look up Hammer Hangers).
    UCAs only affect caster angle (unless you buy the expensive adjustable ones). So unless you are really low on that for some reason (usually fine unless you are above 2" of lift) and getting bad bump steer, new UCA's likely won't do much either. I would put that money into better leafs. Deaver and Archive are the 2 best options. Icon RXT are a decent mid-range option. Stay away from OME and all the cheap ones like Rough Country and Ironman. On a 2014, chances are your factory leafs are too far gone for an AAL to help much. Plus AALs just add more spring rate and make the ride stiffer.
