Will my tires ever be normal again???
Discussion in 'Wheels & Tires' started by wolfspirit, Jul 13, 2008.
  1. Jul 13, 2008 at 7:16 PM
    wolfspirit
    wolfspirit [OP] Member
    My buddy just put 37" swampers on his ride. He gave me his 265/70R16 tires that he took off. I have an 06 Tacoma access cab 4x4. The problem is that he had a bad bearing in the front and his tires that I now have on my truck have a strange wear pattern in them. This is causing the tires to make a LOT of noise running down the road. I put the best looking ones on the front and the more worn ones on the back. I had a full ballance and alignment done when the tires went on my truck. My question is, will the tires eventually smooth out? Being that I have no suspension issues and I am running them on a fully aligned truck I was just wondering if the really harsh / loud noise will become quieter over time as the uneven wear , wears itself out. Also any idea how long that may take. He bought them brand new and they only had about 8000 miles on them. They are Federal and have a pretty aggressive tread pattern. Thanks a lot for any input.
  2. Jul 13, 2008 at 7:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    how bad is the uneven wear??? its possible that they may get pretty close to being back to normal, if they arent real bad, but i dont think that they will be back to being all the way even. try running different pressures in them to start. but you did the right thing putting the bad ones on the rear....being that they are the drive tires, it may help them out a bit.
  3. Jul 13, 2008 at 7:27 PM
    wolfspirit
    Thanks for the response. When you said run different pressure in them what exactly did you mean? I am running the front at about 40 and the rear at about 38.5-39. What pressure do you recommend? The min is 35 and max is 65.
  4. Jul 13, 2008 at 7:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    basically, what i mean is run the pressures to where you get a smooth as possible ride, as you dont want the pressure too high..........it will wear the tire out alot quicker that way.
  5. Jul 13, 2008 at 7:44 PM
    wolfspirit
    gotcha, but do you think that I should run like 50-60psi in the back. Maybe that will make them wear quicker and that will get rid of the bad wear pattern that they have now.
  6. Jul 13, 2008 at 7:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i wouldnt suggest that you run them that high.........just remember, if you do run them that high in the rear, they will wear out in the middle and they will start cupping real bad, since there is no weight back there, having that much pressure in them will cause the rear end to bounce alot more, and that will lead to them being worn worse than they are now. i would run comfortable pressure, and haul something kinda heavy in the bed to help even them out.
  7. Jul 13, 2008 at 8:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    In my experience, tires dont get better. Run them at the propper pressure, and rotate them when needed. You cant "make" them wear back to a normal state once they have been worn down. If they are faulty, they need to be replaced. :)
  8. Jul 14, 2008 at 3:52 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Chris4x4 is correct, once bad, always bad, for the amount of money invested into your truck don't sell yourself short and wreck the truck or wear other parts out because you got some "free" tires, there not free, you'll pay something. :rolleyes:
  9. Jul 14, 2008 at 5:49 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    That depends on how bad the wear is. I agree that they may never get right but it dosent mean that they will go out or give trouble. I don't believe they will ever get quite though.chris4x4 concrete jedi Haven't I seen you guys on other tire post?
  10. Jul 14, 2008 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  11. Jul 14, 2008 at 6:00 PM
    concrete jedi
    Rochester N.Y
    I've been on a couple of them, but a lot of the time it's the same old questions, which tires will fit my truck ?, do I need to lift ? blah blah blah. I pulled this information from experience from work, we go through a lot of tires.
  12. Jul 16, 2008 at 7:20 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I was being sarcastic, we were dicussing how to properly inflate tires the other day and somone was arguing a mute point with chris.
  13. Jul 16, 2008 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, I have been trying to get that thread outta my mind! :D
  14. Jul 17, 2008 at 3:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What kind of tires are they?
  15. Jul 17, 2008 at 5:28 AM
    wolfspirit
    They are Federal M/Ts 265/75R16. From what everyone is saying here, I'm just going to have to replace them with new ones. I've looked at all the threads and looks like people really like the BFG Revos. Any thoughts?
  16. Jul 17, 2008 at 5:53 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    bfg=all terrain, bridgestone=dueler revo...................both awesome tires...pricey, but worth it.
