will my tires fit on these?
Discussion in 'Wheels & Tires' started by cgs2k2, Jun 20, 2010.
  1. Jun 20, 2010 at 2:40 PM
    cgs2k2
    cgs2k2 [OP] Ohio Member
    Nadeem
    2006 AC 4x4 OR
  2. Jun 20, 2010 at 2:45 PM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    You might want to check to see if the wheels will clear the calipers.
  3. Jun 20, 2010 at 2:45 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Yes. Your tires will fit on the wheels. But if the wheels fit on your truck is another question.
  4. Jun 20, 2010 at 2:46 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    The TRD offroad rims are 7 inches wide.
    I'm running 265's on a 9 inch rim with no problem, so you're good to go with the 8 inch wide rim.
  5. Jun 20, 2010 at 2:47 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    Nice! Good to go as far as clearing the brakes and such?
  6. Jun 20, 2010 at 2:49 PM
    KPT
    09 Prerunner
    That's another story, as Tim and Andrew pointed out. There are some styles of 16's that won't clear the cailipers.
    Mine are 18's so I can't help you there.....your best bet is to do a little searching around here and see if you can find anyone on here with those rims, and ask them if they cleared without issues.
  7. Jun 20, 2010 at 2:54 PM
    cgs2k2
    Nadeem
    2006 AC 4x4 OR
    Gotcha gotcha. Thanks for the help! I did some searching before I posted this thread up and couldn't quite find the info i needed, but i'll keep snooping around.
