Will my toytec coilovers settle?
Discussion in 'Toytec Lifts' started by MikeyD, Jan 10, 2010.
  1. Jan 10, 2010 at 6:55 PM
    MikeyD
    MikeyD [OP] Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    I have just ordered some toytec coilovers. I have a 4cyl so im guessing its because of the engine weight difference is why i got way more than 2.5"s of lift out of them when i installed them. I got 4.5"s of lift at first. I then adjusted them. Right now im at about 3.5"s of lift. I left them at 3.5 because i figured they would settle a little. My question is will the settle? and about how much?
  2. Jan 10, 2010 at 8:39 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    They will settle but how much depends on the alignment of the stars. I think everyone is a little different.
  3. Jan 12, 2010 at 1:47 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    question. these measurements you speak of, are they a 'before and after' measurements?
    If they were, you have to realize that you probably had some front-end sagging prior to installation. Even tho you got 4.5 inches over what your suspension was sitting out, doesn't mean you got 4.5 inches of lift over stock. See the difference?
    The springs do settle some, but not a ton.
    What lifting option do you have in the back?
    Do you have a side profile photo of the truck with the kit on?
  4. Jan 12, 2010 at 2:13 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Mine did but not a lot. Nothing you can't fix with a slight adjustment.
  5. Jan 12, 2010 at 8:15 PM
    MikeyD
    Sayreville NJ
    I realize what you are saying. This is from before and after measurements. But i also measured from the center of the hub and that was 24.5"s. I believe before lift it is about 20"s. If some one with stock suspension can verify that would be great. i adjusted them a little and now they are at 23.5"s from the center of hub to the fender. I believe I am at about 3.5"s of lift now. And i dont think i had that much sagging. My truck is a 2007 regular cab with 30,000k on it.
    And ill make sure to get some pictures of the side of the truck on level ground by tomorrow. Thanks for the help, Mike
  6. Jan 13, 2010 at 12:18 PM
    MikeyD
    Sayreville NJ
    Here is a picture of the truck on level ground
    And I have 5100's with a 2" add a leaf in the rear.
  7. Jan 13, 2010 at 12:28 PM
    Toytec Lifts
    Rocky Mountains
    see how level it is?
    your probably sitting at exactly 3 inches of lift up front.
    To level the front with the back, you need just 3 inches up front.
    If the front was raked high, then you would be more likely at 3.5 or 4.
  8. Jan 13, 2010 at 12:29 PM
    MikeyD
    Sayreville NJ
    So you are saying i should be good?
  9. Jan 13, 2010 at 12:30 PM
    Toytec Lifts
    Rocky Mountains
    I think so.
    there is no way the AAL can give you more than 2 inches of lift so, yeah, I think your fine.
  10. Jan 13, 2010 at 12:33 PM
    MikeyD
    Sayreville NJ
    Thanks for the help I appreciate it!
  11. Jan 13, 2010 at 12:50 PM
    Toytec Lifts
    Rocky Mountains
