will my truck pull 3300 lbs.
Discussion in 'Towing' started by 09access2.7, Sep 7, 2008.
  1. Sep 7, 2008 at 6:20 PM
    09access2.7
    09access2.7 [OP] Member
    Joe
    kentucky
    02 ext cab 4x4 2.7L 5sp
    I'm new to the site. Great info here. Just bought an 09 access 2.7 5sp 4x4 after toyota bought back my 99. I have a 6x12 tandem axle trailer with brakes on one axle that I want to haul a 28 model a ford on. Total weight will be 3300 lbs or a little under. I would not be taking long trips, mostly under 75 miles each way. Will I be safe with a class 3 receiver and the activator III brake controller? What do you think?
  2. Sep 7, 2008 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to Tacoma World! I think you will be fine towing with that set up. :)
  3. Sep 7, 2008 at 6:56 PM
    Bakemono
    Bakemono Wrath of the runbird
    Southern Wisconsin, USA
    '09 Toyota Tacoma regular cab 4x2
    You will be fine. Just make sure you give yourself plenty of stopping distance, because with 3300 pounds behind it, it will take your truck considerably more distance to slow down.
