Will new Bilstein 5100 lift enough to run 285's?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shadowray, Jan 14, 2017.
  1. Jan 14, 2017 at 4:03 PM
    Shadowray
    Shadowray [OP] 3rd Gen back to 2nd Gen...
    Arkansas
    2012 Tacoma TRD Sport
    Looks like the new Bilstein 5100s only lift 2" at the max height of the lift. Is that enough to clear 285/70/17 without additional coil springs?
  2. Jan 14, 2017 at 4:05 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
  3. Jan 14, 2017 at 4:08 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    Small lifts don't help you clear tires. They just raise your ride height. To clear tires you need alignment, wheels (or spacers), and cutting frame/fenders
  4. Jan 14, 2017 at 4:10 PM
    computeruser6
    computeruser6 Nuclear Janitor
    Dirk
    Escondido
    2008 Regular Cab Tundra
    King 2.5 coilovers Nitto Exo Grapplers
    How do you feel about cutting? Would you consider a more narrow tire, like a 255/85R16 or 255/80R17?
  5. Jan 14, 2017 at 4:20 PM
    Shadowray
    Arkansas
    I bought 265/70/17 for my 17x9 -12 wheels but thinking of changing tire size and was just curious if the Bilsteins I have will work if I change tire. Haven't installed anything yet
    PhogDog likes this.
  6. Apr 4, 2017 at 12:03 PM
    masmik
    masmik Active Member
    2017 Tacoma TRD Sport DCSB
    i'm running the old 5100 @ 1.75" and clearing 275/70/17 with no rubbing/trimming. i am also running oem mud guards.
    question: is anyone running 285/70/17 @ 1.75"? if so did you need a trim? rub?
  7. Apr 4, 2017 at 12:50 PM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    I dont know what trim package you have, but I can confirm that 285s will fit with the 2nd gen 5100s cranked up to the 2.5 setting and stock TRD OR springs and an AAL in the rear.... I've seen in on my buddies truck.
    you MIGHT have to do a little plastic trimming or heat gun work, but if you do, it wont be much.
    and some people (depending on wheels and offset) will have to do the Cab Mount Chop (my buddy didnt)
  8. Apr 4, 2017 at 12:53 PM
    ptm
    ptm Well-Known Member
    East Coast
    2006 Tacoma TRD
    Magnuson Supercharger Bilstein 5100 w/ OME 887s and 3 Leaf AAL Progressive TRD Quickshift TRD Shifter Knob URD Stage III Clutch URD 3" SS Exhaust Diff Drop Performance Steering Bushings Stealth Custom Series 17" SR8s 285 70 17s Toyo Open Country AT IIs Leather throughout, include leather padded steering wheel, shift boot and armrest HomeTaco Grill
    no, won't fit
  9. Apr 4, 2017 at 12:59 PM
    DEDAFLO670
    DEDAFLO670 Well-Known Member
    Manuel
    Waipio
    15 Trd sport
    285's will fit but it all depends on tire an wheel combo as well. My brother in-law has 5100 with oem coils set at the 4th notch an has zero rub at all. he's running 285/70/17 good year duratracs with trd pro t4r rims.
