Will new springs fix taco lean?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sixstring, Feb 14, 2015.
  1. Feb 14, 2015 at 11:16 AM
    sixstring
    sixstring [OP] Well-Known Member
    Jerry
    Toronto, Ontario, Canada
    2008 4x4 DCab TRD Sport
    When I bought my truck, the previous owner replaced the passenger side leaf spring because the old one had cracked. I just installed a driver side leaf spring from the exact same supplier and manufacturer and my truck still appears to be leaning left. The truck isn't lifted in any way.
    The passenger and driver side leaf springs are installed roughly 3 weeks apart and are both brand new. I fully expected this to cure the taco lean but I've still got it.
    Will replacing the coil springs help? What's a good source for OEM height/spec coil springs?
  2. Feb 14, 2015 at 11:21 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You can add a 1/4" top plate spacer on the driver's side with the stock top hat studs
  3. Feb 14, 2015 at 11:49 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I've put stock replacement Moog brand springs in the front of a 1st gen tacoma and in the rear of a 3rd gen 4Runner and never had a problem with them. But a lot of these trucks tend to lean anyhow. A top plate spacer might be a better solution.
  4. Feb 14, 2015 at 4:23 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I would suggest you measure from the frame to the floor before you spend a lot of money.
  5. Feb 14, 2015 at 5:14 PM
    OZ-T
    Peter North
    British Columbia
  6. Feb 14, 2015 at 6:27 PM
    sixstring
    Jerry
    I should probably try that. I've been doing tire to fender.
  7. Feb 15, 2015 at 4:43 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  8. Feb 15, 2015 at 4:48 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    There is a discrepancy in mine measured that way but it is deal flat from the frame to the floor all the way around the parts are bolted on, the cab is bolted on the bed is bolted on. It kind of like doing a front end alignment by looking at it.
  9. Feb 15, 2015 at 9:34 AM
    OZ-T
    Peter North
    British Columbia
    I don't have one
  10. Feb 16, 2015 at 10:43 PM
    sixstring
    Jerry
    Hmmm I dunno... Shims seem like a way to cover up the problem rather than fixing it. $70 gets new Moog front springs which doesn't seem that bad. Or maybe this is the que to get a lift.
    Anyways I'll measure the frame to ground first right after things defrost a bit around here.
  11. Feb 16, 2015 at 10:46 PM
    OZ-T
    Peter North
    British Columbia
    Battery and gas tank are on the driver's side
    It's called Taco lean
