Will no cat converter hurt motor
Discussion in '1st Gen. Tacomas (1995-2004)' started by garyp, Aug 9, 2013.
  1. Aug 9, 2013 at 6:31 PM
    garyp
    garyp [OP] Well-Known Member
    Gary
    Germantown TN
    97 Taco
    I was just wondering before I spend $ if driving without cat would hurt the engine by running too lean or rich. Previous owner removed it and check engine light stays on, po141, po441.
  2. Aug 9, 2013 at 6:32 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    yes the motor needs back-pressure.
  3. Aug 9, 2013 at 6:33 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    well, considering that ive seen guys drive just fine with nothing but header on the V6, i think you'd be fine, but emissions will fine you into the middle of next week.....
    Edit: im not talking long distance everyday, but down the street to your exhaust shop is fine
  4. Aug 9, 2013 at 6:41 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    To speak generally...damage can be done by running to lean...and there's no way you'll do that with a naturally aspirated vehicle.
    Running too rich isn't going to do anything but hurt your wallet at the pump.
    And running no cats doesn't mean you have 0 backpressure.
    That said to speak specifically...my truck runs like a raped ape with a supercharger and gutted cats. The factory exhaust manifolds and piping are restrictive on the stock 1st gen provide enough backpressure that the truck runs perfect.
    If you want to just fix the check engine lights, just pick up an O2 simulator from URD.
    tacomakid96 likes this.
  5. Aug 9, 2013 at 9:34 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    I don't think it would hurt the motor, but probably hurt fuel economy, installing a urd o2 sim would probably help all around. No p0420 code?
  6. Aug 9, 2013 at 9:35 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Nope. Just hurts the environment
  7. Aug 9, 2013 at 9:37 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What all these guys up top said ^^^^ don't hurt the environment! Lol, just kidding, whatever...
  8. Aug 10, 2013 at 1:49 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    OP, NO, assuming that your engine is a 2rz
    I removed mine over a year ago, at the same time I had a Magnaflow muffler installed
    The money that I spent on the URD sensor simulator and Magnaflow was well worth it, it has more than paid for itself in gas and it sounds much better :)
    I used to get 22 mpg back and forth to work, for the last year I have been getting a steady 25 to 28, it just depends if I keep my foot out of it, for the most part I keep my foot out of it and get 27 to 28, Hwy I get 30 to 31
    I have not had it on a Dyno but it picked up a little
    As far as the environment goes, My Taco refuses to go green, it thinks scientists have lied to us
    Here is the URD sensor simulator link
    http://urdusa.com/Electronics-Rear-...,-2RZ-FE-2.4L-,-3RZ-FE-2.7L/product_info.html
    I had to send mine back for them to tweak it, but it was worth it, check engine light has been off since then
  9. Aug 10, 2013 at 5:21 AM
    garyp
    Gary
    Germantown TN
    97 Taco
    Thanks very much for the urd link, and advice. The 97 Taco runs great with rebuilt 2.7, and a turbo muffler.
  10. Aug 10, 2013 at 9:43 AM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Wtf, back pressure is almost irrelevant on a EFI engine. You can run catless, you'll just throw a code and the engine will try to correct itself, giving a bad fuel mix.
    Buy a cat, or get an O2 sim.
  11. Aug 10, 2013 at 11:23 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not to forget.... It's illegal to run without it.
  12. Oct 9, 2013 at 12:46 AM
    Flight Risk
    Flight Risk Member
    Tony
    WV
    2011 TRD Off-Road
    3" ToyTec Suspension Lift, Alpine INE-S920HD, Devil Horns by Andres, 255/85R16 BF Goodrich KM2's
    1. Back pressure is an old myth. Engines don't need it, period.
    2. The ECU has enough authority to change the a/f ratio enough to compensate for any modifications you do to your air intake or exhaust by interpreting information sent to it from the primary o2 sensor. (In other words, the ECU can change the amount of fuel delivered to the engine by about +or- 15% depending on what the primary o2 sensor is telling it)
    3. The secondary o2 sensor is not used for a/f ratio adjustments. It simply tells your ECU if your catalytic converter is operating correctly or not.
    To answer your question though, it will not harm the engine and you can either get an o2 simulator to remove the codes from being generated, reinstall a cat, or live with it the way it is.
    I don't have any emissions testing that I have to deal with where I live so I will probably remove my cat after the warranty runs out in an attempt to increase my fuel mileage a bit but I don't expect it to help much.
  13. Oct 9, 2013 at 9:47 PM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Dont expect to pass inspection without one :p
