Will not go in gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by Timothyepowell, May 19, 2012.
  1. May 19, 2012 at 3:11 PM
    Timothyepowell
    Timothyepowell [OP] New Member
    Timothy
    Mississippi
    1996 Tacoma 2wd 2.4l
    I have changed my master,slave cylinder put in new clutch kit still won't go in gear. Any help would be great
  2. May 19, 2012 at 4:49 PM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    It could be your throw out bearing. Mine seized up and Ihad to replace it. How long sense clutch was replaced?
    EDIT: Saw your last post... Are you sure it is the right bearing?
