Will not idle??
Discussion in 'Technical Chat' started by vtxal, Jan 19, 2013.
  1. Jan 19, 2013 at 10:20 AM
    vtxal
    vtxal [OP] New Member
    CA
    04 SR5 p/u
    04 4cyl. stick. It was running fine...no issues.... drove it Thurs... ran fine ... Friday it starts right up... stalls...hhhmmm... start it up again ... stalls. start it up again & keep my foot on the gas & it runs smooth as long as I keep the rpms at 1000 or above. When it stalls it doesn't cough or choke or sputter... it just dies.
    No mods.... No recent service.
    Any Ideas ?
    I did a search here first but couldn't find a similar issue.
    Thanks
  2. Jan 19, 2013 at 10:22 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    EGR valve or vacuum leak. Check vacuum hoses. Stick your finger under the EGR valve and push up on the diaphram to make sure it moves and is not stuck open or closed.
  3. Jan 19, 2013 at 11:51 AM
    vtxal
    CA
    04 SR5 p/u
    Thanks Steve
    EGR valve seems to be working....... not able to locate any vacuum leaks.....
