Will not pull boat (for Jay) up an incline
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rilo2448, Apr 23, 2019.
  1. Apr 23, 2019 at 1:49 PM
    #61
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Are you sure your trailer brakes aren’t stuck or maybe your e brake is engaged?
  2. Apr 23, 2019 at 1:50 PM
    #62
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    The more I read this thread, the more I think there is some user error at play.
  3. Apr 23, 2019 at 1:50 PM
    #63
    Rilo2448
    Rilo2448 [OP] Active Member
    cj13058
    #1the fuel tank is full but like you said still under 5500LBS
    #2 have even put the boat in the water yet
    #3 is very possible i just got the boat but the brakes seem to work fine
    #4 No the are surge brakes
  4. Apr 23, 2019 at 1:51 PM
    #64
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    OK OP, bear with me here.
    Asphalt drive
    Decent tires,
    Trailer brakes not locked up
    Load is under the max tow limit
    The hill does not look as steep as the boat ramps in my area
    The truck bogged down the first two attempts. The third attempt you shut off Trac and floored it, spinning the tires.
    Is all of this correct?
    xxTacocaTxx likes this.
  5. Apr 23, 2019 at 1:51 PM
    #65
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  6. Apr 23, 2019 at 1:52 PM
    #66
    Rilo2448
  7. Apr 23, 2019 at 1:53 PM
    #67
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    You continue to blame the truck and folks here despite having a little fun - are trying to help. As has been explained to you, unless there is something mechanically wrong with the truck - in which case the dealer needs to get involved with a warranty claim - the truck is not the problem. Therefore something else is causing said problem.
    Folks are trying to help but you need to explain the circumstances in a clear and logical manner.
    nomnomtaco and tcjacado like this.
  8. Apr 23, 2019 at 1:53 PM
    #68
    coopcooper
    alberta canada
    Is the neck seized? could be an issue with the mechanism in the trailer locking up the brakes.
  9. Apr 23, 2019 at 1:54 PM
    #69
    Shellshock
    Iowa
    Not sure if there’s an issue with the truck, or user error. I’m going with the latter.
    I’ve pulled more weight up steeper grades without issue.
    nomnomtaco, Lt. Dangle and Dryfly24 like this.
  10. Apr 23, 2019 at 1:55 PM
    #70
    Dawdaw808
    Dawdaw808 Well-Known Member
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
    Sounds like your traction control to me :notsure:
  11. Apr 23, 2019 at 1:55 PM
    #71
    Rilo2448
    coopcooper no sir the surge brakes seem to work fine .
  12. Apr 23, 2019 at 1:57 PM
    #72
    Dawdaw808
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
    :cheers:
  13. Apr 23, 2019 at 1:57 PM
    #73
    Roddy13
    Roddy13 Well-Known Member
    Traction control is cutting your power. You need to disable it....
    Dryfly24, Shellshock and Dawdaw808 like this.
  14. Apr 23, 2019 at 1:58 PM
    #74
    JNG
    Based on this then I would suggest since you do not have four wheel drive and cannot use four low, the next time you pull the boat up this hill put the trans in S1, push the ECT button, turn the locker on and don't be afraid the give the truck a bit of throttle. This will give you the most torque and traction your truck can deliver.
    rtzx9r and xxTacocaTxx like this.
  15. Apr 23, 2019 at 1:58 PM
    #75
    Rilo2448
    I'm going to take it to the dealer and see if they can look at it
    BadCow and InfernoChalupa like this.
  16. Apr 23, 2019 at 1:58 PM
    #76
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Are you trying to backup the truck up hill with surge brakes?
  17. Apr 23, 2019 at 1:58 PM
    #77
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    I bet the surge brakes need to be adjusted, or the coupler itself. A quick recap on how surge brakes work: the hydraulic brake master cylinder on the trailer is activated by pressing against the back of the tow ball.
    Most surge brakes have a lock out for reversing; try that when going uphill on your driveway.
    InfernoChalupa likes this.
  18. Apr 23, 2019 at 2:04 PM
    #78
    gw204
    gw204 Well-Known Member
    Get the boat loaded with everything you normally carry for a day on the water and then pull it to a truck scale so you can get an accurate weight. Have someone video your attempts to pull up the driveway so you can show the dealer exactly what is happening, both from inside and outside the vehicle.
    There should be no reason why you cant pull that size boat up an incline like that.
  19. Apr 23, 2019 at 2:06 PM
    #79
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Ah shit man. I’m sorry. It looked like dirt.
    Something is definitely wrong then. Those tires are perfect for what you are trying to do.
    So I would definitely be looking at brakes and tongue weight then. Seems to me the back of the truck has no weight for traction.
  20. Apr 23, 2019 at 2:11 PM
    #80
    BadCow
    BadCow Well-Known Member
    David
    2019 Tundra TRD PRO Super White
    Stop beating yourself up over this dude, and just take it in to the dealership. Life is good, you will survive this bump in the road.
