Will Offset Fix Fender Flare Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FadeToGray, Aug 22, 2021.
  1. Aug 22, 2021 at 5:56 PM
    FadeToGray
    FadeToGray [OP] Member
    New England
    2016 TRD Sport
    Icon Stage 3, 33" BFG KO2s with Level 8 Wheels, Victory 4x4 Bumpers, Sliders, and Roof Rack, Flowmaster Exhaust, and a lot of Lights.
    Hey all, currently running 16x8 wheels with a -10 offset and 285/75/16 tires.
    2.5" Icon Stage 4 lift. Cab mount chop complete.
    Under hard left turns where the nose dips a bit, the drivers side front tire is banging against the fender flare.
    I don't want to have to trim the flare, so I'm wondering if I went to a 0mm offset instead of the -10mm would that pull the tire in enough to clear the fender flare? Or is there another solution aside from cutting the fender / flares.
    Thanks in advance.
  2. Sep 23, 2021 at 1:08 PM
    tacosandnoodles
    tacosandnoodles Member
    Denver, CO
    2018 TRD OR DCSB
    Following.
    I'm about to do this but with a 1.5" Bilstein 6112/5160 setup. Did you rub a lot more before the CMC?
    For what it's worth, from everything I've read so far (not experience), 16x8 0 offset with 4.5" backspacing with 285/75/16 should not be an issue, especially after CMC.
