Will rubbing hurt my truck or tires?
Discussion in 'Off-Roading & Trails' started by longhairedhippy, Oct 22, 2021.
  1. Oct 22, 2021 at 10:51 AM
    longhairedhippy
    longhairedhippy [OP] I never go full redneck
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Bunch of stuff bolted on, some cool, some not
    Ok, I've taken off my LCA skids. Off to the tire shop to get another alignment and I'll see what it looks like after that.
  2. Oct 22, 2021 at 10:52 AM
    eon_blue
    Azusa, CA
    If they can push the caster more positive now that the LCA skids are off, that would help clear the cab mount more. Might still need to do a CMC though
  3. Oct 22, 2021 at 1:21 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Yeah, make sure you dont get a “toe n go”. Tell them what’s going on and ask for a before and after readout
    longhairedhippy[OP] likes this.
  4. Oct 22, 2021 at 6:45 PM
    longhairedhippy
    Ray
    Seattle, WA
    2019 MGM TRD OR SB
    Alright, looks like we're in business. I asked them to caster as far positive as possible, after talking about the issue, now I think I may actually be in better shape than with the spacer lift. I'm going to go test it out tomorrow, however I hit the lip on my driveway a couple of times with the wheel turned fully in both directions and had no problems (I used to get a little "chirp" rub if I hit it too fast).
    Thanks for all the great info and replies folks, love this community!
  5. Aug 24, 2023 at 3:10 PM
    GatorCountry
    GatorCountry Active Member
    2018 Tacoma SR5
  6. Aug 24, 2023 at 3:11 PM
    GatorCountry
    2018 Tacoma SR5
    My front tires rub my mud guard and it doesn't hurt anything, but anything else it will destroy tires.
